Exploded view of Steering Column - Ford Truck Enthusiasts Forums
Old 01-31-2009, 03:09 PM
HareBall's Avatar
HareBall HareBall is offline
HareBall is starting off with a positive reputation.
Does anyone have a high rez exploded view of a 74 Automatic column?
You know one that shows all the parts.
Old 02-01-2009, 08:26 AM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
This is the best I can do..it's for a 73 with auto. This is only a partial shot of the upper section, the bottom is pretty simple, a bushing and sleeve and a spring, along with the shaft and shift tube. If you can't get this to blow up and it it doesn't explain what you are looking for, let me know and I'll try to get you the full column shot.
<a href="http://s131.photobucket.com/albums/p295/bryd06/?action=view&current=Wheelcopy.jpg" target="_blank"><img src="http://i131.photobucket.com/albums/p295/bryd06/Wheelcopy.jpg" border="0" alt="Photobucket"></a>
Old 02-01-2009, 01:49 PM
armstrongfordtrucks armstrongfordtrucks is offline
armstrongfordtrucks is gaining momentum as a positive member of FTE.
Go to LMC.com 73 thru 79 ford go to page 101
Old 02-01-2009, 02:39 PM
HareBall's Avatar
Quote:
I went to your picture link and it was the same size as the one above.
Old 02-01-2009, 09:25 PM
73FOMO's Avatar
I will try and get you one posted tomorrow of the full column. Sorry you couldn't enlarge that one.
Old 02-01-2009, 11:10 PM
HareBall
If you right click on the page 101 in lmc and place it in your pictures you will be able to make it larger to view.
Old 02-02-2009, 11:45 AM
73FOMO's Avatar
Here you go...
Old 02-02-2009, 02:46 PM
HareBall's Avatar
Thanx 73FOMO.
I just noticed that you are from Dothan. I lived in Enterprise way back in 1980.
I am from Huntsville originally.
Old 02-02-2009, 09:12 PM
73FOMO's Avatar
Cool. I know alot of people from E-prise and Ft. Rucker. Glad I could help. If you are looking for a particular part, give me the number on the drawing and I should be able to reference it to the Ford part #. I was given my truck by my granddad who lived in Nashville, and we are regular visitors to your neck of the woods.....Pigeon Forge/Gatlinburg area....so I have ties to TN as well.
Old 02-02-2009, 09:20 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Here you go...
^^ Illustration: Section 35, page 15 from the 1973/79 Ford Light Truck Parts Catalog.
Note that this illustration is for both manual and automatic columns.
This parts catalog is available on a CD from hipoparts.com for around $25.00.
Old 02-07-2009, 11:26 AM
HareBall's Avatar
What is the trick to re-assembling the column? I can get everything lined up, but can't for the life of me, figure out how to get the two column flange bolts to stay in place.
I thought about taping them there, but really don't want to have the tape left inside the column.
Any help would be appreciated.
Old 02-07-2009, 12:16 PM
HareBall's Avatar
Never mind. I finally got it figured out. It was easier than it appeared to be.
steering column questions spikinfool05 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 12-31-2015 02:31 PM
steering column exploded view wanted ostrx250 1987 - 1996 F150 & Larger F-Series Trucks 4 01-25-2015 12:02 PM
66 Steering Column JefflovesF250s 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-20-2011 12:22 PM
Steering column bearings bashby 1987 - 1996 F150 & Larger F-Series Trucks 12 06-02-2009 01:15 AM
'85 f-150 steering column exploded view WoodN1_76 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-03-2005 02:24 PM
Tags
1948, 1975, 1996, 2002, bronco, column, components, early, econoline, exploded, f100, ford, ranger, steering, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
