Lets see everyones trucks......
  #1051
Old 03-23-2012, 09:48 AM
Coskid's Avatar
Coskid
Coskid is offline
The 35x12.5's for Nittos are actually like 13.5" wide and the 295's are just under 12". The height is close to the same so unless you really like wide tires the 295's are a better option in my choice. Plus the wide Nittos rub on other things then just the bumper because they are so wide.
  #1052
Coskid's Avatar
Coskid
Coskid is offline
Oh and Clint the truck looks great!
  #1053
Old 03-23-2012, 10:02 AM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
So it seems like Nitto's are the only option in that tire size? That's sad. Wonder how cooper's 35x12.5's would do. They say they are a true 12.5".
Drew, did you ever get a chance to do any measuring?
I don't recall seeing any through the 71 pages of pictures(although I could be forgetting)...does anybody have a crew cab with the 6.5' bed that has it lifted, or leveled with bigger tires?
  #1054
Old 03-23-2012, 10:05 AM
Coskid's Avatar
Coskid
Coskid is offline
What was I going to measure for you I forgot?
  #1055
Old 03-23-2012, 10:11 AM
jthorngate3
Haha, no worries. I was just curious what your ground clearance was at a few of the lowest points, front suspension namely(outside and middle).
  #1056
Old 03-23-2012, 10:14 AM
Coskid's Avatar
Coskid
Coskid is offline
The ground clearance from my driveway to the bottom of the rear differential is 9". That appears to be the lowest point on my truck.
  #1057
Old 03-23-2012, 10:15 AM
jthorngate3
You just have the 33's?
  #1058
Old 03-23-2012, 10:53 AM
Coskid's Avatar
Coskid
Coskid is offline
Yes that is correct.
  #1059
Old 03-23-2012, 03:26 PM
jthorngate3
So, feasibly, you would be at 10" with 35's, give or take(mostly take) obviously. Cool. Thanks for the help.
  #1060
Old 03-24-2012, 08:12 PM
2007stlFX2's Avatar
2007stlFX2
2007stlFX2 is offline
Picture of my custom gauge setup after the supercharger was installed. Kind of a crappy picture because i took it with my phone. Trans temp, A/F wideband gauge, and boost!!
Shot at 2012-03-23
  #1061
Old 03-25-2012, 04:11 PM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
Just measured mine. The 295s I have on there actually give me about ten and three quarter inches at the rear differential.
  #1062
Old 03-25-2012, 08:07 PM
jthorngate3
That's pretty decent Clint! How is the front end in comparison? I really love the look of your truck.
  #1063
Old 03-25-2012, 10:12 PM
DieselBeast01
Don't know...didn't measure the front end. It sits a little lower in the front maybe half inch to an inch. The front is independent suspension though so the undercarreage(middle of front skid plate) is higher than the bottom of the pumpkin on the rear axle.
Thanks for the compliment on the truck. It's finally starting to look how I wanted it to.
  #1064
Old 04-01-2012, 12:40 PM
Engineer39's Avatar
Engineer39
Engineer39 is offline
2004 F-150
  #1065
Old 04-05-2012, 02:39 PM
Still Smoking's Avatar
Still Smoking
Still Smoking is offline
Just put new tires on the truck yesterday. They are 315/70/17 Mickey Thompson Baja Mtz. They really fill up the wheel wells nice.
Quick Reply: Lets see everyones trucks......
