Water in oil?
Water in oil?
2001 F150 4x4 SCREW 5.4liter 167,000 miles
The oil filler neck has a thick milky substance (water and oil) built up on it. However the dipstick shows to be normal (no water). Has anybody else had this problem? This has happended twice in the last 2 months. We have had lots of large temp and humidity fluctuations here in Houston. Maybe some moisture is coming in through the cap???
I use penzoil 10w30 au natural (not synthetic)
Usually this can happen with humidity,and temp conditions.Short trips can add to it as well.There is of course a possibility that you have an internal leak,but if the coolant level has remained constant,it couldnt(shouldnt) be a major one.
Unless you have had a recent overheat event,Id just keep an eye on the coolant level, (clean the grunge out of the cap)and change the oil perhaps more than youre usual interval.
markcars
1997-2006 Expedition & Navigator
12-26-2012 11:42 AM
WestG
08-05-2012 01:35 AM
blupastu408w
Escape & Escape Hybrid
17
03-26-2011 04:29 PM
