Aviation/military fuels...????
Old 01-31-2009, 07:57 AM
yoslick's Avatar
yoslick
yoslick is offline
#1 con would be expense, go to a Fleet Farm or local oil company and price kero it's SPENDY!! Definately burns good as I heat with it at my cabin.. Has a very low Jel point as well..
Slick
Old 01-31-2009, 10:40 AM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
kero does not burn as hot as no2 diesel, you will lose power and mpg. it does have a lower gel point so you mix it with diesel to prevnet gelling
Old 01-31-2009, 01:34 PM
kawa's Avatar
kawa
kawa is offline
TJ, Could this vehicle have been "Pickled?" Rog
Old 01-31-2009, 03:41 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Not sure what that means but it don't sound good....Anything is possible. It just showed up via trailer from Wisconsin. We have been tasked with the charitable job of getting it running.
Old 01-31-2009, 04:05 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
Rog
Are you calling that truck a boat
Tim
Its a marine term. To "winterize"
Bill
Old 01-31-2009, 06:06 PM
c00nhunterjoe
what all have you diag'd on the truck so far? does it even try to start? is it smoking? any fuel pressure?
Old 01-31-2009, 06:28 PM
kawa's Avatar
kawa
kawa is offline
Pickling is where a preservative is placed in the fuel tanks, crankcase, diff, tranny etc. The military, (Ours) does this sort of thing, at least they used too. Rog
Old 01-31-2009, 06:32 PM
c00nhunterjoe
the military in my area doesnt.... the method we use is called "park and forget"
Old 02-03-2009, 09:16 AM
Sooper-Doodie's Avatar
Sooper-Doodie
Sooper-Doodie is offline
They do so preserve them, 10/10 oil in everything. I worked for the USAF as a contractor a few years ago at AMARC (boneyard) in AZ. Everything was serviced up with fluids and engines, fuel systems and whatnot were serviced with 10/10 oil.
Old 02-03-2009, 07:27 PM
c00nhunterjoe
i asure, you the stuff we have sitting in the woods is literaly parked there
Old 02-03-2009, 07:46 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Well the truck runs now and I still don't know what was/is in it! I let it pull out of a can with diesel after I emptied the filter and filled with diesel and it fired right up. I think it had more to do with the battery charge than the fuel. Didn't have time to let it charge fully before I started working on it last week so I had to work while it charged.
The AFB it came from said it had a bad injection pump it sure ran good! It should its a 1990 with 43K on it and looks brand new inside and out!
Old 02-03-2009, 08:05 PM
c00nhunterjoe
love those kind of finds
  #28
Old 02-03-2009, 08:17 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
From what I understand it was free to. I can't recall if its the FD or DNR's but its kind of a joint venture.
It was also set up for Halon which can no longer be used so that may have been part of the reason for a new outfit. Cost to refit this one was equal to the cost of a new truck......Who knows it will make a good truck to start with for what they plan to use it for.
smokersteve
01-01-2013 11:51 AM
The other Joe
35
07-09-2010 11:31 AM
adambomb
Bio-diesel, Propane & Alternative Diesel Engine Fuels
23
07-09-2008 09:38 AM
glangwell
09-05-2003 01:39 AM
Quick Reply: Aviation/military fuels...????
