Sct tunes for my x3 tuner
hey guys got some tuner and tunes questions? i seen a few mon back
that spartan has all the free archived sct tunes for the sct xcal2 tunes on their site now they are gone. will and would these tunes work for my sct x3 tuner? backwards compatible?
Index of /~amon/tunes
https://cid-5366fff6538efcfe.skydriv...s?view=details
i found these 2 above sites that have tunes, are there any more sites that have any different tunes out there for the 6.0L diesel? could anybody pm me or email me them to me, thanks alot? btw what is a good tune for low power to preserve my warranty and keep the heads intact?
my ecm code is if anybody want to know: VXCF4DC
TQCKOD2
TQCKOD2
how can that be? i called eric at innovative and he said most if not all of the sct xcal2 x3 tuning done by anyone is with the egr off, since if the egr is still active i would be worried to be runnin a hot tune and the egr is dumping that superheated air into my intake runners, am i not correct here or am i mistaken? it seems foolhardy running a hot tune that is making tonns of smoke and having the egr still active & workin and gettin clogged from it being open or partially open.
I know, several people running hot tunes without studs, but I'm just thinking how would I feel running those tunes if I don't have studs. I'm saying this, because I just had to replace my 35psi boost gauge with a 60psi - one. Guess why? I pushed that 35 to max more often, than I could imagine before. Can you imagine that with bolts trying to hold my heads on the block?
Anyways, I would look into delete the EGR, if I'm you, and just forget about it for the future.
quick question, I'm getting ready to install the x3 does it save to stock tune on the device or can I only put 2 custom tunes on and then the stock would be 3 or can you put 3 on and then it saves the stock tune too. I also thought I read some where that you have to backup your stock tune what does this mean. Do I download it first and then put it on the computer then put the custom tunes on or what.
I loaded 3 tunes into the X3 and then plugged it into the truck. The X3 first saved my stock tune then I loaded the new tune into the truck. I think backing up your stock tune means loading it into a file on your computer so you'll have it " backed up" I have to do this yet as I still have my stock tune on the X3 only.
sweet thanks I was alittle worried there for a min not sure if I would still have my stock tune. Hope all works well I'm returning it back to stock (taking off the six-gun)and then putting on the x3 with the spartan tunes then putting the six gun back on so I can use the PDA for the gauges I'll put the six-gun on 1 I think that will be a stock tune so I don't blow the heads off
on
on
I liked this post cause it now gives me ideas on, how I want my next tunes to be. I can now say to someone that's creating my tune what I tried, what I liked about it, what I didn't and, areas I want to improve on. Which I think is better then just getting a tune emailed for the mods done to your truck.
That's great this thread gives you some ideas for what you want. The guys I listed are still in the scene and can offer technical support if needed.
