4X4 - LOW RANGE not working - Ford Truck Enthusiasts Forums
Old 01-30-2009, 07:17 AM
bang4dabuck bang4dabuck is offline
bang4dabuck is starting off with a positive reputation.
4X4 works but not the LOW RANGE. What are the usual suspects in this situation ?
thanks
Old 01-30-2009, 08:45 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Is your truck manual or electric shift?
Are you following the correct procedure for shifting into 4LOW?
Old 01-30-2009, 10:19 AM
nnero's Avatar
nnero nnero is offline
nnero is gaining momentum as a positive member of FTE.
What do you mean it doesnt work? The t-case shifter on my truck has seized up before. It would go into 4 hi, but the shifter would not push down to go into N or 4 low. If this is the case, lube the linkage underneath the cab and try to work it back and forth. The shifter had to be removed to get it freed up on my truck. Make sure to lube these linkages frequently, especially if you do not use 4 low a lot. But this depends on whether or not you have a manual shifter, like the last poster said. Hope this helps.
Old 01-30-2009, 10:51 AM
John Irwin John Irwin is offline
John Irwin has a good reputation on FTE.John Irwin has a good reputation on FTE.John Irwin has a good reputation on FTE.
More info is needed. Push button, or manual. Borg Warner or New Proces. If it's electric, look for a wire off at the servo motor. And it has to be stopped and in neutral.
Old 01-30-2009, 11:49 AM
Marc150's Avatar
Marc150 Marc150 is offline
Marc150 is starting off with a positive reputation.
(Not trying to hijack the thread)
I am having the same problem with my low range. It is a push button on the dash. The 4x4 works excellent but the 4low does not work, no clicking nothing. I have tired it in neutral(not moving) with foot on brake, in park and nothing works. Its not that big a deal but I would like to get it working. I do have the ABS disconnected because the fluid level sensor on the master cylinder is bad, could this be the problem?
Old 01-30-2009, 12:32 PM
It is a push button
Quote:
1995 302
What are the procedures ?
thanks
Old 01-30-2009, 01:19 PM
Conanski's Avatar
Quote:
Back of the sun visor or owners manual.
Old 01-30-2009, 01:49 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
If you have an electric shift and it works in 4-HI but not 4-LO and you are in neutral and stopped when trying to go to 4-LO, then I would suspect the MLPS is out of adjustment or is bad.
Old 01-30-2009, 02:02 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
1995 302
thanks
I'm about the fourth person to ask you this - is it a manual or electric shift transfer case????
Old 01-30-2009, 02:37 PM
rostena's Avatar
rostena rostena is offline
rostena is starting off with a positive reputation.
permalink #6 is titled "It is a push button", so im asuming it's electric.
Old 01-30-2009, 02:41 PM
andym's Avatar
I never read individual post titles.
Are you in neutral when you shift to 4LO?
Old 01-30-2009, 04:35 PM
No
NO not in neutral. At a STOP but not neutral. This is probably OE. Will report back later.
thanks
Old 01-30-2009, 08:00 PM
waynaferd's Avatar
waynaferd waynaferd is offline
waynaferd is starting off with a positive reputation.
Quote:
NO NO NO NO NO!!!
That is too much work!!
Snap off the roll pin and never worry about it again!!
Old 01-30-2009, 08:21 PM
andy22285 andy22285 is offline
andy22285 is starting off with a positive reputation.
Quote:
Originally Posted by waynaferd View Post
NO NO NO NO NO!!!
i tried that and could never get it in 4hi, it was 2, n, or 4lo. way too hard to find the detents
push button with no 4lo is probly the shift motor. the only reason i wish my truck was push button is because that motor is 1/3 the price of the goddam manual shift lever.
Old 01-30-2009, 08:41 PM
If it's the motor, you might be better off buying a new one as compared to going to a boneyard like I did. They gave me one for a Bronco, assured me it would work, and it didn't. Since I'm so stubborn about taking my vehicles to someone else to work on, I spent many countless hours messing with it, and never could get it to go. Finally took it to a shop and they put a new motor in, and I had 4X4 again.
4x4 no low range connork 1999 - 2003 7.3L Power Stroke Diesel 14 04-26-2015 05:08 PM
stuck in 4x4 low range dcara 1999 - 2003 7.3L Power Stroke Diesel 24 01-26-2015 06:08 PM
4x4 Low Range problems Biggiebronco92 1978 - 1996 Big Bronco 8 11-25-2009 11:50 AM
Low Range Light Stays On flaminfordman Ford Inline Six, 200, 250, 4.9L / 300 4 08-05-2007 09:51 PM
Low Range won't engage 93 F-150 4x4 Raymond Bourque 1987 - 1996 F150 & Larger F-Series Trucks 2 12-08-2005 09:39 PM
Tags
1989, 1991, 4x4, engaging, f150, lariat, low, problems, range, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
