Refreshing & clearing browser cache
IF you are having issues with not being able to edit post, insert images, links, etc. find your specific browser and follow the instructions.
Internet Explorer
To reload a page and bypass the cache:
either: Hold the Ctrl key, and press F5.
or: Hold the Ctrl key, and click the Refresh button on the Start bar.
To completely clear the cache (see note above):
Internet Explorer 7
Click “tools”, "Delete Browsing History", and then "delete all". Make sure to click on the checkbox also delete settings stored by add-ons. Then click OK.
Old versions
Click on 'Tools' and then 'Internet Options' and choose the 'General' tab. Then click on "Delete..." under "Browsing history". In the 'Temporary Internet files' section, click 'Delete Files...'. You will then get a dialogue box asking if you want to delete just the temporary files, or all offline content. Choose the latter and click 'OK'.
To change cache settings (only do this if you are reasonably confident of what you are doing):
Selecting 'Tools' → 'Internet Options' → 'Temporary Internet files' → 'Settings...' allows you to make advanced configuration changes to the cache.
There is an option labeled "Check for a new version of stored pages:" This does not bypass the cache, it merely determines how often the browser asks if there is a newer version available.
Mozilla family
This includes Firefox, Netscape Navigator (versions 6.x and 7.x) and SeaMonkey.
either: Press both Shift and Ctrl and then press R. (Alternatively, hold down the Ctrl key, and press F5.) On a Mac, use the Command key instead of Ctrl.
or: Hold down the Shift key, and click the Reload button on the navigation toolbar.
From the 'Edit' or 'Tools' menu, choose 'Preferences' or 'Options'. Expand the 'Advanced' options and choose 'Cache' or 'Privacy'. Click the button called 'Clear Cache'.
In newer versions of Mozilla Firefox, you can easily clear the cache, history and cookies: Hold down the Ctrl and Shift keys, and press Delete (or Del), then choose what you want to remove. Or from the 'Tools' menu, select 'Clear Private Data'.
For older versions of Mozilla Firefox, go to 'Tools' → 'Options' and click on 'Privacy' (picture of a key) in the sidebar of the window that pops up. Click the 'Clear' button that is next to the word 'Cache'.
To disable caching (only do this if you are reasonably confident in what you are doing):
For Firefox
Choose Tools | Options...
Choose Advanced at the top
Choose the Network tab
Change the cache size to 0 (zero).
For SeaMonkey
Choose Edit | Preferences...
Expand the Advanced item near the left bottom
Choose Cache item
Change the Size value to 0 (zero).
FireFox has memory caching, which might also need to be considered when troubleshooting cache-related issues.
In the address bar, enter 'about:config'
Filter the configurations options by entering 'cache' in the filter at the top
Change browser.cache.memory.enable to FALSE
Safari
for version 3 or newer:
either: Hold down the Command key, and press R.
or: Click the Reload toolbar button.
(In Safari 3, "regular" reloads will always bypass the cache. [1])
for version 2 or older:
either: Hold down the Command and Shift keys, and press R.
or: Hold down the Shift key and click the Reload toolbar button. (This may not work in all versions of Safari)
From the 'Safari' menu, choose 'Empty Cache...' or hold down the Option and Command keys and press E.
To disable the cache permanently (this method only works on old versions of Safari 2 on OS X 10.4 and previous versions, and is not recommended as it may potentially (although rarely) cause system instability):
Quit Safari by choosing 'Quit' from the 'Safari' menu, or by holding down the Command key and pressing Q.
Open a Terminal window by double-clicking 'Terminal' within the 'Utilities' folder, which is within the 'Applications' folder.
Type the following commands, which are case-sensitive, each followed by the Enter key:
rm -rf ~/Library/Caches/Safari
touch ~/Library/Caches/Safari
Quit Terminal by choosing 'Quit' from the 'Terminal' menu, or by holding down the Command key and pressing Q.
Relaunch Safari.
Google Chrome
To clear the cache:
Go to the Tools menu (the wrench on the upper right of the browser) and click on Clear browsing data...
Select the types of data you want to clear
On the Clear data from this period: drop-down list, select one of the following:
Everything to clear all the data you selected;
Last day to clear the data only from the last day;
Last week to clear the data only from the last week; or
Last 4 weeks to clear the data only from the last 4 weeks.
Opera
Reloading a page:
Press the F5 key to reload from the web (and bypass the cache)
Or hold down the Shift key, and click the Reload button on the navigation toolbar.
Or Empty the cache completely (see below).
Or Click edit this page, and save the page without making any modifications (this doesn't affect the page history).
To completely clear the cache :
From the 'Tools' menu, choose 'Preferences'. Expand the 'Advanced' options and choose 'History'. Click the button called 'Empty now'.
Alternatively, you can easily clear the cache, history and cookies: From the 'Tools' menu, choose 'Delete private data'. Click 'Details', make sure that 'Delete entire cache' is selected, and then choose any other data you want to remove.
To disable the cache permanently (only do this if you are reasonably confident of what you are doing):
From the 'Tools' menu, choose 'Preferences'. Expand the 'Advanced' options and choose 'History'. Click on the dropdown for 'Disk Cache' and select Off.
Konqueror
either: Press F5.
or: Click the Reload button on the toolbar.
(Unlike other browsers, Konqueror seems to bypass its cache whenever you reload a page.)
From the 'Settings' menu, select 'Configure Konqueror'. Scroll down to select the icon labeled 'Cache', and click the button labeled 'Clear Cache'.
Flock
Go to the Tools menu and click on Options
Go to Privacy and then, under Privacy, click on Cache
Click on Clear Cache Now
Flock v1.0.8 for Mac Instructions:
Go to the Flock menu and click on Preferences
Go to Privacy tab and then, under Private Data (bottom field), click on the Clear Now... button
Select the Cache checkbox (only, or in combination with other desired options)
Click the Clear Private Data Now button
Internet Explorer
Internet Explorer 7
Old versions
Mozilla family
For Firefox
For SeaMonkey
Choose Cache item
Safari
Relaunch Safari.
Google Chrome
To clear the cache:
Opera
Reloading a page:
Konqueror
either: Press F5.
Flock
Y2KW57
User Gallery & Picture Display
01-28-2014 10:33 PM
Earl
23
10-10-2005 10:21 AM
