1999 F250 Super Duty with Limited Slip Diff - Ford Truck Enthusiasts Forums
Old 01-29-2009, 08:27 PM
1L243's Avatar
1L243 1L243 is offline
1L243 is gaining momentum as a positive member of FTE.1L243 is gaining momentum as a positive member of FTE.
I have 77K on my 1999 Super Duty. I bought the truck two years ago with just 23K on it. The truck sat for a while and was not used very much. I had the truck about a year and started hearing a howling coming from the rear diff. I took it into a shop and they (insert long story here) eventually replaced the carrier bearings which one was in very bad shape. I also had them replace the pinion and axle bearings. The ring and pinion were in good shape and did not need to be replaced. After picking the truck up there was still a little noise not very loud coming from the diff when at that point where your not under a load around 50mph. The shop said you may get a little noise because the ring and pinion may be running in a little differnet location? Plus being that I have a camper shell on it makes the noise seem louder than normal. I just let it go and have been living with it for about year but now it's really starting to anoy me. Is this a problem that is caused from setup of the ring and pinion and can it be corrected If I take it to a NEW shop?
Any Thoughts? Thanks
Old 03-16-2009, 01:42 PM
HogginNboggin9 HogginNboggin9 is offline
HogginNboggin9 is starting off with a positive reputation.
its probably the ring and pinion if they really replaced all the bearings that u say they replaced, if the preload and backlash are out of spec it will make noise, it can be corrected by adding shims to get the perfect gear mesh.
My question is instead of dumping all this money into this rear for parts and labor why dont you go to the junkyard and get a whole new rear axle, if its a 99 superduity the truck has a 10.25 full floater rear axle. they go for about 75 bucks at pretty much any junkyard and will bolt right in. make sure to get the same gear ration so u can use the 4 wheel drive withour grenading ur transfer case
- and im sure u kno but look for the (L) in the middle of the gear ratio for a limited slip, for example 3L55
F 350 pinion seal, u-joint replacement, and differential cover replacement nvrsadi 1999 - 2003 7.3L Power Stroke Diesel 10 05-17-2016 06:19 PM
2010 F150 Ring & Pinion - replaced 4 times! CMOS 2009 - 2014 F150 5 09-10-2015 10:42 AM
Crap, Overtightened pinion bearing Aviduser 1997 - 2003 F150 7 05-09-2015 12:49 AM
Tags
01, 1999, 2003, differential, duty, f250, ford, howling, limited, loud, noise, rear, slip, super, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
