2004 FORD F150 5.4 FX4 4x4 oil change - Ford Truck Enthusiasts Forums
Old 01-29-2009, 04:30 PM
rocky3539 rocky3539 is offline
rocky3539 is starting off with a positive reputation.
I just changed the oil in my truck the book called for 7 quarts, I also changed the filter, I dumped 7 quarts into it, started the engine and let it run for a couple of minutes, waited probably 20 minutes and checked the level of oil on the dipstick and it was only half ways between the low level line and the full level line does it take 7.5 quarts with a filter change or should i just as i did and dump 7 quarts in it and leave it alone.
Old 01-29-2009, 06:59 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
it's 7 qts only
your oil level is just fine.
anything between "Add Oil" and "Full" is considered normal
Old 01-29-2009, 09:15 PM
ggwash21's Avatar
ggwash21 ggwash21 is offline
ggwash21 is starting off with a positive reputation.
Yup mine is the same. I actually changed my oil twice in one day thinking i for got something and half way up the hash marks. If you put 7 qts in you are just fine.
Old 01-30-2009, 06:14 AM
dixiemudder04's Avatar
dixiemudder04 dixiemudder04 is offline
dixiemudder04 is starting off with a positive reputation.
Yea i had mine changed at the dealer and thought they were f-ing me over cause i thought 5.4's took 6 qts. And the bill said 7.
Old 01-30-2009, 09:33 AM
ggwash21's Avatar
I think the older 5.4's took 6 but I know these newer 5.4's are oil hogs lol.
Engine oil capcity for 5.4L triton 74broncosport 2004 - 2008 F150 7 02-22-2014 09:45 PM
Oil Question… bigdaddyII 2009 - 2014 F150 4 08-07-2013 06:24 PM
Oil Change question tk3445 Ranger & B-Series 8 06-13-2006 02:54 PM
low oil pressure - no oil to filter armstpe FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 26 04-29-2005 12:58 PM
Oil capacity 6 quarts w/filter?? 1995 f150 xlt 4x4 302 Paul4545 1987 - 1996 F150 & Larger F-Series Trucks 22 03-27-2005 06:02 PM
Tags
150, 2002, 2004, 54, capacity, change, changing, engine, f150, filter, ford, fx4, oil, type, video, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
