400 cam for for heavy towing - Ford Truck Enthusiasts Forums
Old 01-29-2009, 02:30 PM
Spook1 Spook1 is offline
Spook1 is starting off with a positive reputation.
400 cam for for heavy highway towing
My freinds have all went the 429/460 route but I want to keep my 400. I don't want to get out of the throttle because of detonation while towing my 10000lb trailer up steep, long, western mountain passes. I know that wide open might mean 40 to 50 miles an hour in some spots. The 400 might not be perfect for this, but I want it to be as good as it can be. I am pulling my motor for rebuild and would like some cam suggestions. This is the setup I'm considering.
Cam ????
Block/heads decked to get 8.5cr with stock pistons
1.73 rockers(stock ratio)
Dual plane non Egr manifold
4V 650 carb
dist curved for non Egr appl.
Straight up timing set
Headers
C6/4.10 gears/31 inch tires
Thank you
Old 01-29-2009, 02:49 PM
hollenjoe's Avatar
hollenjoe hollenjoe is offline
hollenjoe is starting off with a positive reputation.
Ofcorse its possible with a 400, however i recomend you use 0 decked 9.5:1 pistons
( TMeyer, Inc. - Machine Shop Prices ), a comp cam extreme enegry xe262h cam, with roller rockers, a weiand dual plane manifold, a 650 carb, and a straight up doble timming chain. You should be pushing something like 360hp@5000 and 460lbsof torque@3000, more than enough to push 60miles-h with that trailer...
Old 01-29-2009, 03:05 PM
I am concerned about detonation with that load, 9.5 cr, and pump gas.
Old 01-29-2009, 04:21 PM
hollenjoe's Avatar
you can machine the pistons for 9.2:1 and use 87 or 91 for extreme loads, with the 9.5:1 you can use 91 and 93 with extreme loads...
Old 01-30-2009, 11:08 AM
MBDiagMan's Avatar
MBDiagMan MBDiagMan is offline
MBDiagMan is gaining momentum as a positive member of FTE.
You gave a good rundown, but you failed to talk about your transmission and your driving style.
First off, do you have a REAL transmission for this job, or just an automatic?
Secondly, are you one to spin it up to mid range RPM when pulling, or are you one that feels more comfortable keeping the RPM's down?
With an automatic I would keep the compression a LITTLE lower and use something like a COMP 252H. If it's a manual and you don't mind spinning it up some, I would stay with the same family, but move up to the 262H.
The KEY component that I looked for in your list of items was headers and I am assuming that you are running full length headers and not shorties. With full length headers, and low enough CR to run the Comp 252H, you might find a few of your friends that run 385's being envious of your low end torque.
Old 01-31-2009, 02:32 AM
MBDiagMan
The tranny is good. I would be more comfortable with lower rpms. I drive this truck daily so durability is important.
Tim
79 F250 supercab 4X4
Old 01-31-2009, 04:11 AM
MBDiagMan
The tranny is good. I would be more comfortable with lower rpms. I drive this truck daily so durability is important. No mud bogs no sand dunes just heavy towing and hauling firewood out of the mountains.
Tim
Old 02-02-2009, 10:25 AM
MBDiagMan's Avatar
With your low compression ratio and your tendency to not spin an engine up, I think that a Comp Cams 252H would be ideal for you. You don't need a dual pattern because you have headers, and you don't need the torque peak moved to a higher RPM.
The Comp Cams 252H will build higher cylinder pressure and is designed for your compression ratio. Also, these cams if using their lifters, an oil concoction with adequate ZDDP additive and properly broken in will last as long as the rest of the engine. It also will be easy on the other parts of the valvetrain.
Are you familiar with proper oil and break in for flat tappet cams? Most of todays oils are formulated for roller cams, not flat tappets, so you will need to use the correct oil and/or additive.
You will find much discussion in this forum if you are not already aware of the details of this issue.
Old 02-04-2009, 01:29 PM
Thank you, your assistance and time is appreciated.
Old 02-04-2009, 06:30 PM
JBradley500's Avatar
JBradley500 JBradley500 is offline
JBradley500 is starting off with a positive reputation.
for the power difference in buying a custom ground cam i would have to say that i would go that route. calling someone like mike jones will be worth your time and money.
?? about thermactor setup during rebuild (Piston, Cam, Intake swap) lazzarruss 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-27-2014 06:00 AM
Rebuild 2150 carb or buy aftermarket carb and/or intake? johaner78 Fuel Injection, Carburetion & Fuel System 10 12-07-2005 01:26 PM
isky racing cams ya or na? f350/400 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 10-29-2004 09:43 PM
Recommend SF Bay Area shop for rebuild? packlet N. California Chapter 5 08-16-2004 02:50 AM
Choosing intake for a 400 in a 78, EGR or non-EGR? kevinstang 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 10 08-23-2002 01:19 PM
Tags
252h, 400, cam, ford, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
