?Trans problem? 94 IDI turbo not shifting right
Old 01-28-2009, 10:52 PM
cowboy.2010's Avatar
cowboy.2010
cowboy.2010 is offline
Hey I have a 1994 auto 4x4 IDI stock turbo truck I dont no fer sure what kind of trans it is but it does have the over drive on the shifter and I think its a E4OD The problem is that it dont shift right you have to let off the gas just a hair so it will shift and the overdrive light blinks on and off the whole time but It will go out of overdrive if you hit the button. I was wondering if anyone can help me out thanks
Old 01-28-2009, 11:38 PM
rupejosh's Avatar
rupejosh
rupejosh is offline
you tach sensor is bad it will cause your torque converter to act up,its about a $50 dealer only part.your fipl may need adjusted too.if you need to know how to do it a can take pictures of mine its a 94 idi factory turbo as well.
Old 01-29-2009, 12:19 AM
joe f350's Avatar
joe f350
joe f350 is offline
i wonder where u were rupe
Old 01-29-2009, 01:49 AM
David85's Avatar
David85
David85 is offline
How are your cluster gauges working? Tach and speedometer need to read acurate and steady.
You may want to check the FILP sensor (ford speak for throttle position sensor). I wonder if some one may have changed the setting to get a firmer shift. Read the last paragraph on this page for info on how to check and if needed, reset the FILP sensor:
Ford diesel 6.9 7.3 IDI
Old 01-29-2009, 03:06 PM
cowboy.2010
The gauges are all working and I think are all right I drove the truck today and it shifted somtimes on its own but it would girk pretty bad when it went into gear and it shifted at about 2 1/2 rpm and the overdrive light stays blinking The guy we bought it from said the light stoped blinking a couple times and he said he thinks it shifted normaly, but when it started blinking it would do that again.
Old 01-29-2009, 03:08 PM
cowboy.2010
can the tach sensor be bad and all the gauges and speedometer work ?
Old 01-29-2009, 04:43 PM
David85's Avatar
David85
David85 is offline
If the overdrive light is flashing, then you need to have the transmission codes scanned. I've heard that autozone stores will do this for free.
Old 01-29-2009, 06:45 PM
EMD_DRIVER's Avatar
EMD_DRIVER
EMD_DRIVER is offline
Here are a couple of pics, to show you how to pull the codes. You will need to hold the throttle pedal to the floor, or you will get a FIPL out of range error.
Old 02-01-2009, 05:20 PM
ford trans tech's Avatar
ford trans tech
ford trans tech is offline
have someone with a scanner read your codes for you
using an analog meter and jumper wire requires some experience and it is too easy to erase the codes without retrieving them
and it would be cheaper to have the codes read than to start replacing good parts
Transam461
09-10-2016 12:58 PM
regidog
16
07-17-2016 05:21 PM
big ole ford
05-22-2016 11:06 AM
Coz2122
03-27-2015 08:39 PM
elsmith
07-15-2001 10:59 PM
Quick Reply: ?Trans problem? 94 IDI turbo not shifting right
