?Trans problem? 94 IDI turbo not shifting right
Hey I have a 1994 auto 4x4 IDI stock turbo truck I dont no fer sure what kind of trans it is but it does have the over drive on the shifter and I think its a E4OD The problem is that it dont shift right you have to let off the gas just a hair so it will shift and the overdrive light blinks on and off the whole time but It will go out of overdrive if you hit the button. I was wondering if anyone can help me out thanks
on
You may want to check the FILP sensor (ford speak for throttle position sensor). I wonder if some one may have changed the setting to get a firmer shift. Read the last paragraph on this page for info on how to check and if needed, reset the FILP sensor:
Ford diesel 6.9 7.3 IDI
The gauges are all working and I think are all right I drove the truck today and it shifted somtimes on its own but it would girk pretty bad when it went into gear and it shifted at about 2 1/2 rpm and the overdrive light stays blinking The guy we bought it from said the light stoped blinking a couple times and he said he thinks it shifted normaly, but when it started blinking it would do that again.
on
Transam461
09-10-2016 12:58 PM
regidog
16
07-17-2016 05:21 PM
big ole ford
05-22-2016 11:06 AM
Coz2122
03-27-2015 08:39 PM
elsmith
07-15-2001 10:59 PM
