?Trans problem? 94 IDI turbo not shifting right - Ford Truck Enthusiasts Forums
Old 01-28-2009, 11:52 PM
cowboy.2010 cowboy.2010 is offline
cowboy.2010 is starting off with a positive reputation.
Hey I have a 1994 auto 4x4 IDI stock turbo truck I dont no fer sure what kind of trans it is but it does have the over drive on the shifter and I think its a E4OD The problem is that it dont shift right you have to let off the gas just a hair so it will shift and the overdrive light blinks on and off the whole time but It will go out of overdrive if you hit the button. I was wondering if anyone can help me out thanks
Old 01-29-2009, 12:38 AM
rupejosh's Avatar
rupejosh rupejosh is offline
rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.rupejosh has a very good reputation on FTE.
you tach sensor is bad it will cause your torque converter to act up,its about a $50 dealer only part.your fipl may need adjusted too.if you need to know how to do it a can take pictures of mine its a 94 idi factory turbo as well.
Old 01-29-2009, 01:19 AM
joe f350 joe f350 is offline
joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.
i wonder where u were rupe
Old 01-29-2009, 02:49 AM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Quote:
How are your cluster gauges working? Tach and speedometer need to read acurate and steady.
You may want to check the FILP sensor (ford speak for throttle position sensor). I wonder if some one may have changed the setting to get a firmer shift. Read the last paragraph on this page for info on how to check and if needed, reset the FILP sensor:
Ford diesel 6.9 7.3 IDI
Old 01-29-2009, 04:06 PM
The gauges are all working and I think are all right I drove the truck today and it shifted somtimes on its own but it would girk pretty bad when it went into gear and it shifted at about 2 1/2 rpm and the overdrive light stays blinking The guy we bought it from said the light stoped blinking a couple times and he said he thinks it shifted normaly, but when it started blinking it would do that again.
Old 01-29-2009, 04:08 PM
can the tach sensor be bad and all the gauges and speedometer work ?
Old 01-29-2009, 05:43 PM
David85's Avatar
If the overdrive light is flashing, then you need to have the transmission codes scanned. I've heard that autozone stores will do this for free.
Old 01-29-2009, 07:45 PM
EMD_DRIVER's Avatar
EMD_DRIVER EMD_DRIVER is offline
EMD_DRIVER is starting off with a positive reputation.
Here are a couple of pics, to show you how to pull the codes. You will need to hold the throttle pedal to the floor, or you will get a FIPL out of range error.
Old 02-01-2009, 06:20 PM
ford trans tech ford trans tech is offline
ford trans tech is starting off with a positive reputation.
have someone with a scanner read your codes for you
using an analog meter and jumper wire requires some experience and it is too easy to erase the codes without retrieving them
and it would be cheaper to have the codes read than to start replacing good parts
Help!! 94 7.3 idi auto trans e4od problem Coz2122 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-27-2015 09:39 PM
E4od problems 91seventhree Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 03-27-2014 10:50 AM
1994 F250 7.3L IDI TURBO,E40D TRANSMISSION kjjr20 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-16-2014 03:24 PM
1994 F150 4x4 351W E4OD Shifting question and video msufan 1987 - 1996 F150 & Larger F-Series Trucks 4 10-01-2012 09:03 PM
Weak Torque Converter Lockup on E4OD - Options dylan8427 Clutch, Transmission, Differential, Axle & Transfer Case 4 12-16-2010 06:47 PM
Tags
1994, 73, 94, auto, bad, f250, f350, idi, probels, problem, shift, shifting, tach, trans, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
