Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-28-2009, 08:55 PM
excursionism excursionism is offline
excursionism is starting off with a positive reputation.
Warn Hubs for an 05 X
Need to replace the auto hubs on our 05 X, EB, 6.0. Found the Warn Premium Hubs (Warn #38826) that are good for '99-'04 X's, F250/F350. Just sent Warn an email asking if these would work on an '05, but hoping someone on FTE has already done the swap and can confirm. Did a search, but came up empty.
Was there a design change on the D60 between '04 and '05?
  #2 (permalink)
Old 01-28-2009, 10:24 PM
Desert 4x4 Desert 4x4 is online now
Desert 4x4 is starting off with a positive reputation.
this should work for the 05 X. The 05 X still had the leafs up front but Ford updated the bumper and grill to match the Superduty of the same year. The 05 X is the same as the 99-04 suspension wise. Hope this helps
  #3 (permalink)
Old 01-29-2009, 05:31 PM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is gaining momentum as a positive member of FTE.
I have the mile marker hubs on my X. 449SS. they are the stainless steel ones. direct fit and super easy install. pics in gallery.
__________________
01 EXCURSION LIMITED, 4X4, V10, 325/50/22 TOYO'S ON CUSTOM POWDERCOATED WHEELS, 07 SUPER DUTY FRONT END, LOTS OF CHROME, 6 TV'S, CUSTOM STEREO, DUAL 175 AMP ALTERNATORS AND DUAL BATTERIES, CERVINI 3" COWL INDUCTION HOOD, CUSTOM MADE HID PROJECTOR HEADLIGHTS, TO MUCH OTHER STUFF TO LIST
  #4 (permalink)
Old 01-29-2009, 10:24 PM
Cardiac69's Avatar
Cardiac69 Cardiac69 is offline
Cardiac69 is gaining momentum as a positive member of FTE.
Quote:
I also have the 449SS hubs. I compared them to the Warn Premium's and thought they were made just a little better for less money.....
__________________
Bob
2000 X Limited 4X4 V-10 - Rear Hellwig Sway Bar
Roadmaster Active Suspension
Prodigy Brake Controller - Blue Ox Sway Pro Hitch
2009 Palomino Puma 26BHSS
  #5 (permalink)
Old 01-30-2009, 07:42 PM
Contacted Ed @ FTEPartsGuy and he confirmed the Ford AutoHub part numbers were the same for the 2004 and 2005 Excursion. Then heard back from Warn and after some emails back and forth, they confirmed the Warn #38826 Premium Hubs WOULD work on the 2005 Excursion also.
So now the decision is which brand is better . . . Warn, MileMarker or DynaTrac? I've had great success with Warn hubs in the past. I recall reading a article in DieselTech or DieselWorld magazine when they were trying to improve MPG on a F250 and they swapped in DynaTrac hubs.
So far, personal experience Warn gets the nod . . . a couple of FTE members have MileMarkers . . . anyone with DynaTracs?
  #6 (permalink)
Old 01-30-2009, 09:46 PM
RACERX7775's Avatar
i dont know how hubs are gonna change mpg's. hubs only do one thing, thats to lock or unlock the axles to the wheels. there is no hub on the planet that could change mpg's. here's a pic of my mile markers. i like them better because of the looks and they are stainless steel. you can also see how much shorter they are than stockers especially with aftermarket wheels
__________________
  #7 (permalink)
Old 01-31-2009, 09:27 AM
katiesdad7 katiesdad7 is offline
katiesdad7 is starting off with a positive reputation.
Why do you want to change the hubs? I have an 05 and never used the 4x4 until last November up in GA. I just flipped the switch and presto. Why would you want to do it manually when you can stay warm and clean from inside?
__________________
2005 Eddie Bauer 4x4 w/6.0 PowerSlot Cryo Rotors up front, Hawk LTS pads all around, Bi-Xenon HID's.
Who said size doesn't matter?
  #8 (permalink)
Old 01-31-2009, 10:56 AM
Quote:
Main reason for swap is ~$400 quote from dealer for one after it has froze/locked up. Warn Premiums are anywhere from $185 - $240 for both.
Second reason is I'm 'old school'. I don't like auto hubs and I don't like or want to "flip the switch" on the dash. I want to get out and turn the hub and know it's locked in, not hope the vacuum is working and pulled it in for me. I want to pull a mechanical lever that is attached to my transfer case so I know it engaged, not hope an electrical connection was made pulling in the relays and servos.
And if you're wanting to stay "warm and clean" why are you out on the trails/beach/etc. anyways ? ? ?
j/k
  #9 (permalink)
Old 01-31-2009, 11:01 AM
Au contraire . . . 1979 Chevrolet Pick-up, Full Time 4wd from the factory with big block, 6-9MPG. Swapped in a set of Warn manual hubs and mpg increased from 6-9 to 12-18. It's all in the application.
And by the way, I do like the looks of those MileMarkers
  #10 (permalink)
Old 01-31-2009, 11:53 AM
RACERX7775's Avatar
ok, well you jus said it yourself. FULL TIME 4WD. did that mean that the front axles were engauged all the time. then if so, of course when you have the ability to free up the drag then yes, it will affect the mpg. but now, lets take my excursion, it came with the factory auto-locking hubs. i changed them out to the mile markers. there is no way for mpg's to change. and in the example above given by yourself in post #5, using an f250, they weren't fulltime 4x4's. it is all in the application. when i first stated that it was impossible, i was ONLY speaking for the excursions and super duty trucks.
oh, thanks for the compliment on the pics.
__________________
  #11 (permalink)
Old 02-02-2009, 12:39 PM
ok, well you just said it yourself. FULL TIME 4WD. did that mean that the front axles were engaged all the time. then if so, of course when you have the ability to free up the drag then yes, it will affect the mpg. but now, lets take my excursion, it came with the factory auto-locking hubs. i changed them out to the mile markers. there is no way for mpg's to change. and in the example above given by yourself in post #5, using an f250, they weren't fulltime 4x4's. it is all in the application. when i first stated that it was impossible, i was ONLY speaking for the excursions and super duty trucks.
Yes, the 79 Chevrolet was full time 4wd, the axles engaged and the front drive shaft always turning.
Found the article regarding the Dynatracs . . . had my project vehicles mixed up. Diesel World installed the Dynatrac Free Spin HD Hub conversion on their Project Underdog, a 2004 F250, not on their Project MPG, another 2004 F250. In the article they state "The kit also comes with chromoly spindles, cast nodular wheel hubs and Warn premium locking hubs. This combination of parts not only eliminates the Ford factory weak link bearing assembly, but gives you free-wheeling hubs for improved mpg (my highlight & italics), larger axle shafts to handle big torque loads and larger tires . . . " (ref pg 62).
So now my question is, in "Auto" are the stock front hubs NOT free-wheeling? Not arguing, just learning.
Also, found Dynatrac now offers a kit for the 05 - 07 Suoer Duty's
Dynatrac 2005 - 2007 Ford Free-Spin Hub Conversion Kit
  #12 (permalink)
Old 02-02-2009, 01:21 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE.
The stock hubs do free wheel in Auto if the switch is off, if they are working properly.
The blurb in the article is probably info from Dynatrac's site. Their Dodge kits give increased MPG as they do not have locking hubs. The Ford kits only improve MPG if your have a hub that isn't unlocking.
The 05+ Free Spin for the new coil spring front axles has been available for a while now, good kit. Not as popular as the new unit bearings are better and bigger than the old style.
__________________
DC
2001 F-350 PSD 4x4 Hell Raiser, Heavily Modified
2007 F-350 PSD 4x4 Work Horse, Moderately Modified.
Other 2wd PSDs: 99 F-450, 00 F-450, 01 F-350, 02 F-350, 02 F-550, 04 F-450, 06 F-450
  #13 (permalink)
Old 02-02-2009, 03:00 PM
Quote:
Thanks for the clarification. Wasn't sure if "Auto" = "free-wheeling" (with everything working properly).
What are you making reference to when you said "Not as popular as the new unit bearings are better and bigger than the old style." Is there a better Dynatrac offering (or other manufacturer?)
  #14 (permalink)
Old 02-03-2009, 03:23 PM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE. 1 is gaining momentum as a positive member of FTE.
Quote:
Glad my extended warranty covered new ones for me when I compalined mine were frozen. If this set were to go bad and I still owned the truck I would go to the stainless ones.
__________________
03 Excursion Limited SOLD!!! Shopping for an 08+ 6.4 Super Duty
99 Camaro SS, Procharged, Forged 370, LS6 Intake, TH400/Brake, Fabbed 9", Kooks, Yella Terra, etc.
96 Impala SS, K&N, Hyperjunk Programing, 160 thermo, Muffler Detete, TV/DVD yadda...
88 Cutlass Supreme Classic, Forged 331, 11:1, Open Headers, TH350, Stupid Big Cam
  #15 (permalink)
Old 07-30-2009, 11:32 PM
blowhole's Avatar
blowhole blowhole is offline
blowhole is starting off with a positive reputation.
Subscribed...
__________________
blowhole
[ 2005 Excursion - Eddie Bauer - 6.0L PS ] : Zoodad w/ Z-Plate : 4" MBRP TB Exhaust w/ 5" tip & No Cat : Thule Rack on stock rails : ISSPro Boost & Trans Temp & EGT : Fumoto Valve
Tags
0507 , better , excursion , f350 , ford , front , hub , hubs , locking , modified , pictures , premium , replacement , superduty , warn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
