i'm trying to buy a lower radiator hose but i'm unsure by what they mean by oil cooler. do they mean trans oil cooler or engine oil cooler. i do have a trans cooler
Since you were asking about a lower RADIATOR hose I would suspect they are asking about an engine oil cooler, My 97 F-250 w/351 OBS has an engine oil cooler and it DOES use a different lower hose..
With oil cooler the two small hoses come out about 3 to 5 inches or so from the water pump...
no they mean oil cooler, there is a fitting at the oil filter which allows the engine coolant to pass through and cool the oil. i think they are on 351's, i definitely know the lightnings had them.
I'll have to look more into this. I know many trucks have a cooler at the bottom of the radiator but I'm pretty sure it was for the transmission. I have a secondary cooler since I have a tow package, but I'm pretty sure it routes in sequence with the cooler at the bottom of the rad.
Dang cold and dark, I'd go look now if I could...been a while since I've been under there.
Mine has that too, seems kinda hokey. I'd like to put a regular radiator hose on the bottom and run a normal oil cooler up front. Kinda sucks you have to use that short oil filter too.
Besides Lightnings the only 351 trucks I've seen with the radiator hose oil cooler are 1994 and newer. These take the FL820s oil filter instead of the FL1A. Every one I've come across has had one, so they were probably standard equipment?
