Ford 5.4 vs Chevy 5.7,5.3 - Ford Truck Enthusiasts Forums
Old 01-28-2009, 09:50 AM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
How does the Fords 5.4 compare to the Chevy 5.7,5.3
Old 01-28-2009, 01:14 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
They're all V8 gas engines.
Published specs says they are all close in output so they should and do perform similarly. It's hard to make a meaningfull comparison unless the engines are in vehicles with the same weight, gearing, and tire size, but that's not usually the case with articles you see so you have to take it for what it is.
Old 01-28-2009, 03:48 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
I had a 2000 Silverado 1500 with 5.3 and 3:73 rear. Good solid engine. Quick and got 2-3 mpg better than my 5.4. I think the Chevy was a tad quicker than my Ford but the Ford has 3:55 gears and bigger tires.
Old 01-28-2009, 04:31 PM
Thanks for the replies. Anybody have horsepower numbers for each engine. Torque numbers as well.
Old 02-01-2009, 02:25 PM
Mawk Mawk is offline
Mawk is starting off with a positive reputation.
Quote:
What years are we going to compare?
That'd be a good place to start.
Old 02-02-2009, 04:39 PM
DirtStripHero's Avatar
DirtStripHero DirtStripHero is offline
DirtStripHero is starting off with a positive reputation.
My best friend has a 2005 Silverado with the 5.3. My dad has a 2004 F150 with a 4.6. Both are regular cab long bed, with similar tires. I'm not sure what the gearing is in the Silverado( 3.54 I think) but dad has 3.73 in his. The chevy is quite a bit faster and gets better mileage. But when it comes to towing, the Ford wins hands down.
Old 02-12-2009, 12:32 PM
phillips91 phillips91 is offline
phillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud of
i had a 2000 chevy with the 5.3 as a company work truck and ive got a 2000 f250 with the 5.4. hands down the chevy was faster than my 5.4, even though my 5.4 is a 5 speed with 4.10 gears and the chevy was an auto with something like 3.54 gears. the main problem i had with the chevy was that it wouldnt pull itself up a hill unless it was turning 3500 rpms. but it pulled strong in the higher rpms. on the other hand, my 5.4 falls flat on its face and is virtually useless at any rpm above 3k. i think the 5.4 is better for towing because it makes more power at lower rpms and i dont have to constantly downshift.
Old 02-13-2009, 08:15 PM
tealduck0516 tealduck0516 is offline
tealduck0516 is starting off with a positive reputation.
I had a 97 with a 4.6 and raced my cousin that had a 97 chevy with 5.7 vortec. I won for the first 1/4 mile but thats cause of lower gears.
Old 02-17-2009, 09:58 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Depends on so many conditions. I pawned a 2004 2500HD with a 6.0 and 4.10 gears with my truck. But that truck was obviously heavier.
I think the 5.3 might be quicker than a stock 5.4l in the quarter mile, but the 5.4l will probably take the early lead due to the monster torque down low.comparatively. Also put a 5k trailer behind both trucks and then race. I bet the 5.4l would pull through FTW....
Need motor mount help 1962 F100 DSinOR 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-01-2016 10:18 AM
Why does KBB value the1999 F250LD a thousand bucks more than the SD??? MaineHomesteader Offroad & 4x4 88 03-08-2016 10:30 AM
Need help! awillo0406 1999 - 2003 7.3L Power Stroke Diesel 5 09-03-2015 11:40 PM
Replacement Choke Tubes dstraw 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-30-2015 12:12 PM
OT -Chevy copied the 54 Ford Grill Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-03-2015 11:34 PM
Tags
2004, 2005, 46, 53, 54, 54l, 57, chevy, engines, f150, ford, horsepower, mpg, race, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
