300 - 6 cylinder timing
Old 01-27-2009, 06:49 PM
IHF250fireman's Avatar
IHF250fireman
IHF250fireman is offline
I have a 300 inline six cylinder out of an 84 f250. I put it in a 78 f250 but have no way of finding out what motor is spose to be timed at becuase had to change distributors, help would be appreciated
Old 01-27-2009, 09:20 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
If you can give me the number off the distributor I can tell you what it needs to be set at.
Old 01-27-2009, 09:27 PM
06silvercrew
Old 01-28-2009, 08:13 AM
surveyguy's Avatar
surveyguy
surveyguy is offline
oh, i have one of these in my F150, don't forget to find (if you have now that you switched engines?) the SPOUT connector and unhook it while checking/adjusting the timing. You may pull your hair out if not )
Old 01-28-2009, 08:14 AM
aldridgec's Avatar
aldridgec
aldridgec is offline
Good advice, however, this application is mechanical and not electronic. NO spout connector involved.
Old 01-28-2009, 08:21 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
But I think the chart doesn't show what the OP was asking. It appears to me he wants to know what his initial timing should be set at, not the mechanical advance and total timing.
Old 01-28-2009, 10:51 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
And WHY is this in the SD forum?
Better off going to the appropriate forum - thread moved to the correct I6-300 forum
Old 01-28-2009, 12:12 PM
Harte3's Avatar
Harte3
Harte3 is offline
Probably somewhere between 6* and 10* with the vac advance disconnected from the dizzy and plugged. Then one can use a vacuum gauge connected to a full vacuum source to find a starting point by turning the dizzy to the highest steady reading then back off 1-2 hg. Test drive it and adjust accordingly.
Old 01-28-2009, 05:44 PM
06silvercrew
Sounds to me like he is wanting to set the base timing. THe chart I posted gives the specs, NO? Like posted, I would shoot for the 6-10* area.
MachOne
15
04-09-2010 11:40 PM
TheL36Driver
05-19-2008 09:51 PM
baileybilt
31
11-17-2006 10:14 AM
Difles
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
23
10-21-2004 06:25 PM
ecbooks
01-23-2003 09:01 PM
Quick Reply: 300 - 6 cylinder timing
