300 - 6 cylinder timing - Ford Truck Enthusiasts Forums
Old 01-27-2009, 07:49 PM
IHF250fireman IHF250fireman is offline
IHF250fireman is starting off with a positive reputation.
I have a 300 inline six cylinder out of an 84 f250. I put it in a 78 f250 but have no way of finding out what motor is spose to be timed at becuase had to change distributors, help would be appreciated
Old 01-27-2009, 10:20 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
If you can give me the number off the distributor I can tell you what it needs to be set at.
Old 01-27-2009, 10:27 PM
Old 01-28-2009, 09:13 AM
surveyguy surveyguy is offline
surveyguy is starting off with a positive reputation.
oh, i have one of these in my F150, don't forget to find (if you have now that you switched engines?) the SPOUT connector and unhook it while checking/adjusting the timing. You may pull your hair out if not )
Old 01-28-2009, 09:14 AM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Quote:
Good advice, however, this application is mechanical and not electronic. NO spout connector involved.
Old 01-28-2009, 09:21 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
But I think the chart doesn't show what the OP was asking. It appears to me he wants to know what his initial timing should be set at, not the mechanical advance and total timing.
Old 01-28-2009, 11:51 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
And WHY is this in the SD forum?
Better off going to the appropriate forum - thread moved to the correct I6-300 forum
Old 01-28-2009, 01:12 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Probably somewhere between 6* and 10* with the vac advance disconnected from the dizzy and plugged. Then one can use a vacuum gauge connected to a full vacuum source to find a starting point by turning the dizzy to the highest steady reading then back off 1-2 hg. Test drive it and adjust accordingly.
Old 01-28-2009, 06:44 PM
Quote:
Sounds to me like he is wanting to set the base timing. THe chart I posted gives the specs, NO? Like posted, I would shoot for the 6-10* area.
300 six cylinder question MachOne Ford Inline Six, 200, 250, 4.9L / 300 15 04-10-2010 12:40 AM
Cylinder head for 300. TheL36Driver Ford Inline Six, 200, 250, 4.9L / 300 12 05-19-2008 10:51 PM
5 speed mazda tranny to heavy tranny baileybilt Clutch, Transmission, Differential, Axle & Transfer Case 31 11-17-2006 11:14 AM
Turbo on a 300 6? Difles Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 23 10-21-2004 07:25 PM
firing order for 300 6 cylinder 89 f 150 ecbooks Ford Inline Six, 200, 250, 4.9L / 300 0 01-23-2003 10:01 PM
Tags
300, 78, adjust, advance, cylinder, expedtion, ford, inline, set, setting, sgow, time, timing, total, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
