Thump, thump, thump...
Old 01-27-2009, 01:26 PM
CanadianSmokie's Avatar
CanadianSmokie
CanadianSmokie is offline
I am hoping someone has an idea on what is causing my latest annoyance. There seems to be a thump, thump, thump sound that i can also feel through the floor pan. It is intermittent and only at speeds over 40 miles an hour. Mostly starts during a decel or when I'm cruisin with no pedal in it. Sometimes stops when i accelerate, sometimes gets a little worse.
The trucks going in the shop on Thursday to get the upper and lower ball joints done on the passenger side as well as a U joint on the drivers side.
Do I have a bad drive shaft support bearing maybe? Do these even have a rear drive shaft support??
Thanx for any and all answers. I will take a good look under there when the trucks on the hoist but suggestions as to where to look would be appreciated..
Old 01-27-2009, 02:57 PM
cbradford's Avatar
cbradford
cbradford is offline
Check universal joints for rear drive shaft.
Old 01-27-2009, 04:42 PM
Nairns05's Avatar
Nairns05
Nairns05 is offline
thump thump thump
I was having simular noises on my 05 excursion as well. It was hard to follow the noise because it accured so erratic, but yes the noise sounds like your truck is falling apart. Anyways I took it in to the dealership and found that the ball joints on the left side were bad. I replaced them but the noise was still there so I replaced the sway bar bushings to now have the front end silent. It was so easy to replace the bushings and it made all of the difference in the world. Dan
Rays auto
1999 to 2016 Super Duty
09-06-2016 10:49 PM
atwoj0
Escape & Escape Hybrid
01-01-2016 12:49 PM
dutchnichols
09-26-2014 09:29 PM
rideracelivemx7
13
02-18-2011 07:00 PM
iron1951
28
09-16-2010 06:47 PM
Quick Reply: Thump, thump, thump...
