Low range switch
01-27-2009, 12:23 PM
Low range switch
Does anyone know if the low range input to the PCM is active in a 4X2 truck, or will I have to swap PCM to get the low range shift points right?
01-27-2009, 12:42 PM
The PCM doesn't know anything about low/hi range. Neither does the transmission.
01-27-2009, 04:24 PM
on
Yes.
Its pin #14 to access 4X4 low shift schedule.
It just has to be a auto trans pcm code.
Handshaker pcm will not have it.
Bill
01-27-2009, 04:47 PM
Thanks MADVAN!
I didn't figure it would be needed with the handshaker...
I still second guess just going to a handshaker, but I'm going down the E4OD 4X4 route.
01-27-2009, 04:59 PM
on
You can also access the 4X4 low in the E-Series auto's
Bill
