2002 brake pressure switch/cruise control switch? - Ford Truck Enthusiasts Forums
Old 01-27-2009, 02:01 AM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
I did some searches and found some info, but not enough. What is the proper name of the sensor/switch on the end of the brake master cylinder? Its the one with the recall fuse/wiring harness added on to it. (already had the recall part put on) My truck is leaking brake fluid from this area. I need to replace it and haven't found it online. I'm hoping to avoid a trip to the dealer. Does the whole part get replaced, with the metal mount, or just the sensor/switch inside of it? Also, how much of a mess is this gonna make when I pull the part? Need to bleed the brakes after?
Is this the part? It looks like the sensor, but not sure.
O'Reilly Auto Parts
Is this it? Looks the same, but with the wiring includedRock Auto
Old 01-27-2009, 06:38 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Speed Control Disconnect Switch is Ford's name.
It just screws into the the master cylinder without requiring bleeding.
The switch and harness is less that $20 at a dealer if you ask for the recall kit.
Steve
Old 01-27-2009, 07:30 AM
fireball 440's Avatar
fireball 440 fireball 440 is offline
fireball 440 is gaining momentum as a positive member of FTE.fireball 440 is gaining momentum as a positive member of FTE.
If you had the recall done already, bring it back to the dealer and demand it fixed for free. This switch leaking fluid is what the recall was for.
Old 01-27-2009, 11:23 AM
the recall fix was done over 2 yrs ago, the switch was not leaking at the time. As I understand the recall is an add on wiring harness with a fuse, does not cover the switch. I guess I'll just go get the part at the dealer and swap it myself, don't feel like waiting around all day to get it fixed.
Old 01-27-2009, 04:13 PM
Got the part at the dealer ($22 w/tax) and swapped it out in 15 min. But my cruise control won't work. I rarely use the CC, but I noticed it wasn't working when I noticed the leak, so I assumed it was related. I checked the fuse under the dash, still good. Is there another fuse under the hood, manual didn't mention one. Don't have any CEL light, everything else is working. Anything else I could check. Don't use the CC much, so I guess I'll just leave it alone.
Old 01-27-2009, 04:28 PM
92merc 92merc is offline
92merc is starting off with a positive reputation.
That "link" the dealer would have installed as a part of the fix is nothing more than a fuse. Odds are you've blown that. Quick test would be to just remove that link and hook it direct. If that works, get the link replaced. Or make your own.
Old 01-27-2009, 08:12 PM
thanks, I'll check that out. Now that I remember there is a fuse holder in that recall harness. Just gotta check if I can open it, or if it's sealed. The new switch came with short harness, I asked the parts guy if I should use it or just take off the recall harness and use the new one. He said to just plug it into the recall harness. I wonder if there is another fuse in that new harness?
Old 01-27-2009, 09:21 PM
To do so would be a complete waste of times, both yours and the dealer's. If the recall was performed as prescribed and the switch was not leaking at that time, they have fulfilled their obligation under the terms of the recall. Once the fused harness is installed, the vehicle is protected from harm if the switch should fail in the future. THAT was the purpose of the recall, not the prevention of some possible future functional failure.
Or just unplug the recall harness from the vehicle harness and plug a jumper into the vehicle harness. A paper clip will do the job for testing to see if the cruise now works.
FWIW, for a 2002, you should be running the cruise self-test first.
Steve
Old 01-27-2009, 09:41 PM
fixed it. The fuse in the recall harness was blown, didn't have any 2 amp fuses, so when and got some. Guess it did it's job, truck didn't spontaneously conbust.....
Thanks all for the help!
Is replacing orange injectors with beige Injectors a good idea??? V10exHD Excursion - King of SUVs 9 03-14-2014 01:07 PM
Bough a truck...but I've got problems... V8Notch Modular V10 (6.8l) 8 04-16-2013 08:38 PM
Is this the correct part? ChristopherN 1987 - 1996 F150 & Larger F-Series Trucks 17 11-16-2011 08:47 AM
Which Idler Arm? Fox Fader 1997 - 2003 F150 8 05-15-2011 05:05 PM
rear abs speed sensor question meb9796 1987 - 1996 F150 & Larger F-Series Trucks 18 12-30-2009 12:05 PM
Tags
02, 2002, 2003, brake, buy, control, cruise, cyl, f150, fluid, ford, leaks, navigator, pressure, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
