trailer plug wiring question - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-26-2009, 06:31 PM
bigbubba87's Avatar
bigbubba87 bigbubba87 is offline
bigbubba87 is starting off with a positive reputation.
I Have to rewire the trailer plug on my 2000 f350 to pull our goose neck. The trailer has electric brakes. Orange-power feed all the time White-ground Blue-? Green-turn signal Yellow-turn signal Black with green stripe-? Brown white stripe-trailer marker lights ok i have that much figure out. Are they right? what is the blue wire. and what is the black with a green stripe? im wiring it into just a basic 6 pole round plug in.
Old 01-26-2009, 06:40 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Old 01-26-2009, 06:49 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I had a post a while back that detailed what wire did what... IIRC blue is the feed for the brakes. Black/green is probably reverse lights, assuming you're looking at your factory 7 way plug.
Old 01-26-2009, 06:50 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
The Blue wire is to your trailer brakes (hot, not ground).
The Black is Battery Charge (if your trailer has a battery backup for the brakes.._).
The White is common Ground.
The Red is Stop and LH turn.
The Green is Tail, License and running lights.
The Brown is Stop and RH turn lights.
The "center lug" is Yellow for extra Auxiliary circuit.. (not usually used)
Not sure what your orange wire would be..
You can always check each wire with a ohm volt meter is double check where they are going.. If the trailer has a battery, then one of the wires will be 12v at the trailer plug...
Old 01-26-2009, 08:28 PM
bigbubba87's Avatar
orange has power all the time for the brakes.
Old 01-26-2009, 08:32 PM
rbaker6336's Avatar
according to the link I posted orange is auxillary
Old 01-26-2009, 08:41 PM
sideshow's Avatar
sideshow sideshow is offline
sideshow is gaining momentum as a positive member of FTE.sideshow is gaining momentum as a positive member of FTE.
You said you were re-wiring yours? What kind of plug do you have now, factory? I added a 7way plug in the bed of my truck. I removed the factory plug (just a quick connect behind bumper) and spliced into it a section of 7 way wire i had left over from replacing the trailer side plug on my landscape trailer. I had wiring diagrams, but just make sure the corresponding wires on each plug match. I drilled a hole behind the driver's side tail light, at the widest part of the bed (close to the tie down anchor). I then fished the new wiring up through the wiring access to the tail light, and through the new hole i drilled. Then connect the wires to the back of the female plug. I'll see if I can get a picture.
This way I don't have to worry about the plug flopping against the tailgate, or hanging up on something. I also did it cause i thought it was cool.
Old 01-26-2009, 08:44 PM
sideshow's Avatar
It would have been easier, but I couldn't find an adapter for my year of truck. Hoppy makes a "Fifth wheel wiring kit" which is a quick connect tee that plugs in where the factory harness is now, and has a plug on one end of the tee. The other end of the tee has the bare wires to connect to the female plug. Pretty easy, just disconnect the factory harness, connect the two new plugs, and connect the wires to the female plug. They make them for newer superduties, but i couldn't find one for mine. I accidentally bought one for a newer modlel and realized the pins on the harness didn't match up, so i just returned it, and made my own. About the same price, but more time consuming.
This is what i was looking for but couldn't find. I wonder if it is a new product, because their website didn't have it listed last time I looked.
http://www.hopkinstowingsolutions.co...connector.html
Old 01-26-2009, 09:33 PM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
I believe this is what you are looking for: This is for the ford wiring.
Color - Function
Dark Blue -Trailer Electric Brakes
Orange - Trailer Battery Feed
Yellow - Left Stop Turn
Dark Green - Right Stop Turn
White - Ground
Brown/White - Trailer Running Lamps
Black/Lt Green - Trailer Backup Lamps
Old 01-26-2009, 10:01 PM
bigbubba87's Avatar
cangim that last post was what i needed thanks i am keeping the factory plug but putting a diff plug in on it.
Old 01-27-2009, 08:40 AM
cangim's Avatar
your welcome
Old 01-27-2009, 09:39 AM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
The OP's question was answered, but I figured I would post this pic. I saved the pic in my documents since I can never remember which wire belongs to what.....
Plus we are iced/snowed in today and I'm just drinking too much coffee and a postin' away!
7 Pin Trailer Connector 1L243 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 21 02-03-2015 03:52 PM
89 f250 truck side trailer wire colors and what they are for kawirider00 1987 - 1996 F150 & Larger F-Series Trucks 2 04-07-2011 01:23 PM
1989 Power windows and locks wiring? piersol 1987 - 1996 F150 & Larger F-Series Trucks 8 06-05-2010 07:59 PM
Need some help with wiring. stang_crazy_gt 1967 - 1972 F-100 & Larger F-Series Trucks 2 10-25-2007 01:14 PM
Customer Access Wires . . mikewrt 1999 to 2016 Super Duty 1 10-19-2003 11:49 AM
Tags
2000, 4way, 7way, brakes, diagram, diagrams, f350, ford, picture, plug, stock, trailer, wire, wiring, ww
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
