EBPV wired to brake light for engine braking?
if not, you could always add a relay in line. I don't know anything about this, so I do not know what the current draw would be on the EBPV
I run a T4 setup so i haven't had an EBPV in over 10 yrs but it would be nice to have an exhaust brake; especially for towing. However I thought those created issues of their own on these trucks. I guess I would have to look into it
The following users liked this post:
It also take a couple seconds for it to engage. So by the time it's engaged your brakes are doing most the work so won't get much benefit. The best way to do it is tie it into the idle validation switch at the accelerator pedal so whenever pedal is let off it engages it. Like coasting down a hill with no throttle it engages the exhaust brake. Then of course have a switch to arm it so you can turn it off when you don't want it. Pretty simple to do this way also. Just need a switch and a relay.
Just wire it up to a switch on the dash. I have a 4.88 geared 550 and it was only any good above 2500 rpm as an exhaust brake and it did make a difference but not enough to want to live with the oil leak that it developed a few years later. Bought a delete pedastal somewhere, installed it and moved on in life. I don't go up and down enough mountain passes to make it worth the trouble.
battleriver
07-23-2006 02:29 PM
dalejarrettfan
1997-2006 Expedition & Navigator
01-29-2003 01:54 PM
