Front End Shimmy while braking - Ford Truck Enthusiasts Forums
Old 01-26-2009, 02:49 PM
Beach_Bob Beach_Bob is offline
Beach_Bob is starting off with a positive reputation.
Our 04 Sport Trak has started giving a little wobble on the front end when we're braking. Not much, but enough that if you take your hands off the steering wheel, you can see the wheel vibrate back and forth about an inch.
Brakes seem fine, so I'm kind of stuck on thoughts as to what the issue is. Any suggestions?
Old 01-26-2009, 03:31 PM
highlandescape highlandescape is offline
highlandescape is starting off with a positive reputation.
sounds like the rotors are warped. may need new brake rotors or at least see if the rotors can be turned.
Old 01-26-2009, 03:38 PM
Rotors were just turned, I figured that that was the likely problem as well. Turning them did not change the problem at all.
Old 01-26-2009, 03:44 PM
try new rotors. i have found on rangers and explorers the factory rotors are pretty much junk after the first set of pads are worn. and if midas turns the rotors they seem just as bad.
Old 01-26-2009, 07:02 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Check your Ball joints, tie rod ends and tires for cupping/separation.
Does the brake pedal pulsate when applied??
Old 01-28-2009, 10:43 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
put jacks under both A--frames with front tires a couple inches off the ground. turn one wheel by hand and see if the other turns also or too much slop between them.. on my F150 i had the idler arm bushing wear out and do that. this is the anchor link that bolts to the frame under the radiator area. other end is bolted to the tie rod cross link.
Old 01-29-2009, 03:14 PM
In taking a better look at the suspension, I realized that the passenger front tire looked awfully low. Once inflated properly, the problem seems to have gone away. Go figure.
Steering wheel shakes when applying brakes SOMETIMES Obxbornfree 1968-2013 Full Size Vans 11 09-28-2016 09:36 PM
front brake lines & hoses tomrflorida 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-31-2014 08:54 PM
Brake Vibrabation and Shudder CourierYVR Aerostar 31 08-28-2012 09:40 PM
Brakes causing front end vibration 2003 F250 RWD redepta40 1999 to 2016 Super Duty 3 01-04-2011 08:33 PM
front end shakes bad when i apply brakes AC94EXPLORER Explorer, Sport Trac, Mountaineer & Aviator 10 02-08-2008 02:57 PM
Tags
1991, 2005, braking, end, explorer, f150, ford, front, idler, makes, shimmie, shimmies, shimmy, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
