chains?
chains?
My dad wants to somehow get chains put onto the engine mounts. He says that if they break, it's usually right where the rubber part is, so you want to somehow get chains around that where if it were to break, then engine would still stay in place. While this makes sense, I would think if it were necessary, the manufacturer of the engine mounts would include them with the kit. My engine will only be pushing 330 hp, so it's not like I have a huge amount of torque tearing at them. Do you guys think they are necessary?
What engine and mounts are you using? Most modern 302/SBF and 350 SBC factory rubber mounts are made with an integral safety feature to prevent any bad stuff. Look close at yours, you'll see it prevents the engine from really going anywhere, although it may allow the engine to lift off the mount a ways under power.
In race car/truck applications, some people use a chain, or maybe chains to limit the motor twist.
But since you say its maybe 330 HP you are far from needing limiting chains.
Motor mounts are pretty tough, so don't worry.
I have pushed my poor Saleen to make roughly 900 crank HP, and its motor mounts take that despite many hard launches.
Ross, I actually don't know what the brand of motor mounts these are, but they were recommended by a shop that does custom work. The are brand new, so it's not like I don't know what they've been through. But they will be for the 302 that I am putting in there.
Sounds to me like everyone agree's that it's unnecessary.
I am running a 5.0l from a 91 Crown Vic. it has the safty mounts as mentioned. The 302 that came in my truck was from a 72 F100 and where the style that where just two pieces of metal with a rubber centre glued to the metal pieces. These did work for many years but would pull apart. Just use the newer style and you will be fine.
Received 1,344 Likes
on
73 fourxfour
07-09-2010 01:08 PM
dchamberlain
Fifth Wheel & Gooseneck RV Towing
60
12-23-2008 06:45 AM
jepps
09-22-2005 08:09 PM
