Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-26-2009, 09:37 AM
PsD007.3's Avatar
PsD007.3 PsD007.3 is offline
Garage is empty, add now
PsD007.3 is starting off with a positive reputation.
this work for magnesol???
ok soo we can just put the magnesol in the 55gal drum and just hook some sort of mixer up to a drill and mix it for 30 minutes and just let it sit and all the nasty stuff will go to the bottom and we could just pump the biodiesel out off the top untill we reach the bottom crap that settle out?? and how many grams of magnesol for apprz 40gal?? that include getting methanol out of it also??
__________________
KP
2000 f350 7.3 Dp tuner 60 tow, 80 economy, 140 aggr, sled pull, S300 turbo H2E mounting, carson stauffer complete fuel system with bowl delete, Adrenaline HPOP, swamps 175CC single shots, BTS valve body, TCI torque master TQ 1500 stall, COMP 910s, headstuds, CCV,AIH delete, skyjacker 6inch suspension, RBP 18x10 94R, 37x13.5 Toyo MT
  #2 (permalink)
Old 01-26-2009, 08:11 PM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Gun-Driver is starting off with a positive reputation.
Without removing the methanol you will need approximately 6 pounds for 40 gallons bio, three pounds if you remove the methanol first.
You need 2% per pound/with methanol - 1% per pound/without methanol.
Bio weighs approximately 7 pounds per gallon.
  #3 (permalink)
Old 01-26-2009, 11:14 PM
PsD007.3's Avatar
what if i put the magnesol in my processor that has a an electrical pump..for example after i would let the gylcerin drop could i just put the 5.75lbs of magnesol in through the top of the lid and just let it circulate for about 45 minutes?? then just let it sit over night?? but would it get hard and clumpy over night, where i couldnt drain it through a 1inch ball valve?? like after letting it circulate for just say an hour and i went out the next day what would the magnesol be, like a thick substance?? or clumpy?? like would it be drainable is my question?
__________________
KP
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
