Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 401, 477, and 534 SD Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-25-2009, 08:33 PM
norm426 norm426 is offline
norm426 is starting off with a positive reputation.
477 Engine tech info
Hi AllI am just finishing putting back together my 477, i need some tech information to finish it though.Can any one help with the cylinder head torque settings, the valve lash and the ignition timing?Cheers
  #2 (permalink)
Old 01-27-2009, 12:15 AM
94Sport5sp 94Sport5sp is offline
94Sport5sp is starting off with a positive reputation.
Hi:
Timing of 477 is 6 degrees BTDC at 550 rpm for gas and 10 degrees BTDC for LPG motors. Additonal information can be had in topic 477 Firing Order and Cylinder Number on this board.
Cylinder head bolts are to be torqued to 170 - 180 Ft-Lbs in three stages. first to 140 then to 160 and then to final value. Also the bolts are tightened from the center of the head out and from the intake side to exhaust side. So center intake bolt to 140 and then center exhaust bolt then move one bolt to front and repeat then move one bolt to back and repeat then front bolts then back bolts. Repeat to 160 and then repeat to final torque.
Trust that helps.
PaMnd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
