Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-25-2009, 02:36 PM
PsD007.3's Avatar
PsD007.3 PsD007.3 is offline
Garage is empty, add now
PsD007.3 is starting off with a positive reputation.
HELP...best way to dry biodiesel??
right now we use an 80gal aquarium (sp) air pump with dual air lines that hang to bottom of our 55gal drum and let air pump through the fuel for about 24hrs...
__________________
KP
2000 f350 7.3 Dp tuner 60 tow, 80 economy, 140 aggr, sled pull, S300 turbo H2E mounting, carson stauffer complete fuel system with bowl delete, Adrenaline HPOP, swamps 175CC single shots, BTS valve body, TCI torque master TQ 1500 stall, COMP 910s, headstuds, CCV,AIH delete, skyjacker 6inch suspension, RBP 18x10 94R, 37x13.5 Toyo MT
  #2 (permalink)
Old 01-26-2009, 09:18 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
If you're going to water wash and bubble dry you need to put airstones on the air lines to break the bubbles up. I also helps to put some sort of dispersion mechanism to spread the bubbles out.
Better yet don't water wash use Magnesol to dry wash then no drying needed. You get a better product and eliminate many problems.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Tags
biodiesel, bubble, bubbles, dry, drying, forum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
