Snake, I am still open to going and will pick ya up if I can get this damn fuel problem fixed I have been screwing arounbd with for the last two months. I am at the point now of dropping the tank to see if the screen is blocked. If it is, there will be no more screen. I will put a filter in front of the fuel pump.
Well buddy, I have not seen ya in a while and would like to do so. I really dont mind at all so the offer is open if you so choose.
Not exactly sure what you have been going through but just an idea from whats posted above.... Disconnect the fuel line before the tank and blow backwards into the tank with an air compressor. If the sock is clogged that will either clear it or more than likely blow it off the pickup tube. Dont forget to remove the gas cap first or you are gonna have a mess on your hands.
Never thought of doing it that way. I will pick up that filter tomorrow.
I was thinking older Fords (had cliffs new beast on my mind) not sure if thats good to do with an EFI truck. Guess I should have looked at your profile first. I would assume there is a pump in the tank and it might not like it.
