Got some work done on the 79 today - Ford Truck Enthusiasts Forums
North Dakota Chapter Join Chapter, Leader: hav24wheel
Old 01-24-2009, 07:57 PM
unrulee's Avatar
unrulee unrulee is offline
unrulee is gaining momentum as a positive member of FTE.unrulee is gaining momentum as a positive member of FTE.
Well I finally got my new rear plastic tank in after removing the extremely rusty stocker that was plugging my carb even with 2 fuel filters on it. Easy fix and highly recommended .
I also put 4 degree shims under the rear axle to get my pinion angle back to somewhere tolerable. After the shackle flip last year I wasn't sure how the d-shaft angle would be....well it was a little to much. Off the line in good traction situations you could feel the rear u-joint binding slightly. After putting the shims in "backwards" and going for a test drive tonight I'm happy to report that all is well . And yes I did repair the vent line that tore off during the RTI session!
Got a little forklift RTI in as well . This time on the front and I didn't chicken out. If I pushed a little on the box the back tire would leave the ground ! I think the shock was topped out . Makes for good pics (but always more impressive in person).
Rotated tires as well, yeah I know pretty boring .
More to come on Sunday.......I hate/love working harder on the weekends than I do all week !
Old 01-25-2009, 12:52 AM
nobodyspecial's Avatar
nobodyspecial nobodyspecial is offline
nobodyspecial has much to be proud ofnobodyspecial has much to be proud ofnobodyspecial has much to be proud ofnobodyspecial has much to be proud ofnobodyspecial has much to be proud ofnobodyspecial has much to be proud ofnobodyspecial has much to be proud ofnobodyspecial has much to be proud ofnobodyspecial has much to be proud of
Nice looking truck, bud. I want to get to work on our trucks, but its too freakin cold! even in the shop!
Old 01-26-2009, 01:51 AM
884x4broncoII 884x4broncoII is offline
884x4broncoII is starting off with a positive reputation.
looks like fun i havent had much time to work on anything with this cold, i cant wait for spring
Old 01-26-2009, 10:32 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
you didn't get much done at all this weekend.. lol. I need to do a gas tank swap on my pickup too, a fuel filter only lasts about 50 hours on the ticker.. i had a busy weekend. i got my shop warmed up, and started a new project. i'm doing a swap for a freind... he is having me swap all the axles and motor trans and tcase out of a 85ish bronco into a 85ish ranger... the bronco had a SAS on the front already.. i'm doing a writeup over on FSB if your interested. FullSizeBronco.com - 78 - 96 Ford Bronco forums, tech, installs and more.
What kind of shim did you use(whats it made of)?
and did you fix that broke rear breather hose that is visable in that one pic?
Old 01-26-2009, 06:28 PM
unrulee's Avatar
I dealt with that rusty tank ever since I bought the truck in '00. I ran two fuel filters and the carb would still eventually plug up with red grit. When I put the Holley on I quit using the rear tank all together. So I'm finally back to two tanks. I'll never have to worry about contaminated fuel again since both tanks are plastic.
I know exactly why your asking what the shims are made of. Hold tight, they're aluminum . I wasn't sure on the angle to get (6 degree or 4 degree), went with 4's and they work. I ordered the shims form BGY thinking that they'ed be steel, ha boy was I wrong. So I figured rather than mess around with the hassle of returning them (they were only $15) I'd just put them in temporarly to see if they were the right angle. Now I need to find some STEEL ones to replace 'em. You got any leads (local would be nice)???
Yeah I fixed the breather the same day (I did mention that in the picture caption ). Thanks for pointing it out anyway.
Old 01-27-2009, 05:11 PM
hav24wheel's Avatar
i tried to edit my post after i reread your original one. i missed it the first time.. must have been lookiing at the pics too much. lol. i can't remember where i saw some steal shims... but i'll let you know if i find them again.
My '64 4x4 izzo 1961 - 1966 F-100 & Larger F-Series Trucks 10 09-28-2015 12:53 AM
1949 ford laying running boards down2earth 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 09-06-2015 02:35 PM
Built myself a Bumper / Grill Guard CaptainIPSC 1973 - 1979 F-100 & Larger F-Series Trucks 37 04-05-2015 10:41 AM
1978 F250 Custom Interior crsweet78 1973 - 1979 F-100 & Larger F-Series Trucks 142 09-14-2014 10:49 PM
the "green machine" '93 4.0 4x4 racsan Ranger & B-Series 5 01-15-2014 12:36 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
