1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
recon 08 mirror signal light brightness question
Old 01-24-2009, 12:36 AM
kengarchow's Avatar
kengarchow
kengarchow is offline
just finished the 08 tow mirror install on my SD and changed to the smoked recon LED signal mirror lenses.
i never saw how bright the OEM signal mirror was or noticed how its visibility was from different angles , but i doesnt look like the recons are as bright as i would like and they dont look to project to the rear like i think the OEM would
has anyone that had the OEM ambers, changed to the smoked, that can give an opinion about there function please
i am thinking of trying to smoke my OEM amber lenses and try them but wanted to get a feel for how the OEM and recon compare before i go to the trouble
thanks
Old 01-25-2009, 10:34 AM
kengarchow's Avatar
kengarchow
ok there better at night, but still not what i think they should be
i learned the smoke process cuts down some of the light.
thinking of doing light smoke on the OEMs. has some one done any experimentation on there 08 signals?
thanks
Old 01-25-2009, 11:06 AM
dew the thunder's Avatar
dew the thunder
dew the thunder is offline
From what I read, the RECONs are LED and the OEM were incandescent.
Old 01-25-2009, 11:40 AM
kengarchow's Avatar
kengarchow
dew i can tell you this is true in my case as i have both, and the 08-09 OEM are incandescent and the Recon are LED.
what i dont have is a way to light them both up to see what the difference is
thanks
Old 01-25-2009, 02:16 PM
dew the thunder
LED only offers a 30º light dispersion IIRC. Which means they really only shine light in one direction. That could have something to do with it. Along with the smoke drowning out the light that is...
Old 01-25-2009, 02:27 PM
kengarchow's Avatar
kengarchow
dew that is what i am thinking, it is a combo the smoke and LEDs that give dim light, but to try the OEMS i have to smoke them and then take my mirrors apart again to install them
so if there are any other opinions it would be helpful too
thanks!!
Old 01-25-2009, 04:20 PM
dew the thunder
I would just grab a 12v battery or battery charger and hook it up to the OEM light... compare from there.
Old 01-25-2009, 05:41 PM
kengarchow's Avatar
kengarchow
dew cant do that the sockets are inside the mirrors and have to take them apart to get to them
thanks
nmclella
12-10-2013 06:11 PM
jpix2013
15
03-14-2013 09:25 AM
F 250 6 liter
10-03-2010 12:50 PM
90F250351
09-15-2009 07:59 PM
CounterMaker
21
06-28-2007 11:03 PM
Quick Reply: recon 08 mirror signal light brightness question
