How to wire 3rd brake light on camper shell?
I'm thinking that I can use a wire off the taillight, but it might blink with the turn signal and that would look stupid.
I have a 5 wire trailer harness behind the rear bumper of the truck, can I use that? There's also a light in the camper that needs hot all the time.
I know this should be really simple, but it has me stumped.
TIA,
Craig
TIA,
Craig
I did some searching with different words and found an answer. There is a green wire with a male connector fastened to the inner drivers fender, near the master cylinder. It's labeled for the 3rd stop light. Now all I need to do is get the male connector and run the wire to the light. Thanks for the help!
Oh, I thought you said you wanted it hot all the time. Makes sense, you'll probably only need it when lights are on. Should be ok if it's like a single bulb dome type light. I pulled all the old wiring on mine, I think it was wired like that if I remember. The light in my topper also has a switch on it. It's an older fiberglass topper, I think it was installed when the truck was new.
Franko72
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
15
04-14-2009 07:33 AM
07F150trucknut
Electrical Systems/Wiring
01-19-2008 03:56 PM
Cowboy Tom
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-28-2005 02:27 PM
