5.0 to AOD seperator plate question...
I decided to go with an AOD transmission in my 56, since its just now being reassembled it was a good time to make the change. So today I clean up the seperator plate and go to mount the transmission onto the 5.0 engine and I find that the starter bolts are misaligned between the plate and the transmission. The starter holes in the transmission are about 1/2 inch farther out than the holes in the plate. All the holes in the engine to plate to transmission line up fine. I bought this engine as a builder and the plate came with so I can't vouch for what it is...could it have been from a manual transmission installation?
D8DZ7007A .. Plate, Engine Rear / Obsolete
No Ford dealer or obsolete parts vendor has any.
Fits: 1980/86: F100/350, Econoline & Bronco / 302 ~ 351W / all with C4; C6; AOD.
Fits: 1978/80 Granada/Monarch 250 I-6 ~ 302 / C4.
Fits: 1979 LTD/Grand Marquis/LTD II/Cougar/Mustang/Fairmont/Zephyr 302 ~ 351W / C4 ~ FMX.
Fits: 1980/82 LTD/Grand Marquis/Mustang/Capri/T-Bird/Cougar/Fairmont/Zephyr / 302 / AOD
Fits: 1983/89 T-Bird/Cougar 302 / AOD.
F4TZ7007A .. Plate-Engine Rear / 302 ~ 351W
Fits: 1987/96: F150/350; Econoline & Bronco all with C6 ~AOD.
MSRP: $41.65 // FTEpartsguy.com price: $29.99
I have been researching the 4r70w forever and come across tons of aod stuff. Go to this page and about 1/3rd of the way down they have a block plate for the aod to small block conversion. Its new with the inspection plate but costs 90 bucks. hope this is what your looking for or helps
http://www.transmissioncenter.org/cl...conversion.htm
Early Mustang AOD Conversion Kit, 1965, 1966, 1967, 1968, 1969, 1970, 1971, 1972, 1973
I wouldn't think that this should be so hard, the engine and the trans are both from an 89 Mustang...it's not like I am trying to bolt an AOD to a Y-block or anything. I guess that I'll have to hit the junkyards on Monday to see what they have lying around.
Your old separator plate may have been for a C4, sounds like the same issue I had when I switched to AOD. I went the same way, new plate from ebay. Just make sure you get the inspection plate too, sometimes they try to sell that separately.
dsmit412
12-31-2016 03:54 PM
GreatNorthWoods
16
04-20-2011 04:29 PM
CharlieLed
11-29-2008 07:20 AM
Craigwell
07-27-2007 10:29 PM
