Rear brake lines
Old 01-23-2009, 06:53 PM
Vinford's Avatar
Vinford
Vinford is online now
Rear brake lines
1979 F-250 4x4
I was changing the passenger side rear brake line as it was rotten and leaking.
Took it off the wheel side OK.
Tryed to take it off the block on top of the rear end and pulled to hard and broke that block off the rear end.
What holds that block on the axle housing?
Its so rusty I cant really tell.
Is it a threaded hole into the axle housing?
How hard is going to be to find a new block?
Old 01-23-2009, 08:05 PM
Fordworth's Avatar
Fordworth
Fordworth is offline
It's a threaded tube that acts as a bolt to attach the tee and a vent for the axle housing. You will have to get the broken part out with an easy out and replace it. If you need to replace the tee you will have to get a new brake line from the frame to the axle, it's permanently attached.
Old 01-23-2009, 08:12 PM
Fordworth's Avatar
Fordworth
Here's a recent thread about the same thing.
https://www.ford-trucks.com/forums/8...s-it-work.html
Old 01-23-2009, 10:04 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1978/79 F150/250 4WD Rear Brake Hose / 1976/79 F100/150 2WD / 1979 F350 4WD
Originally Posted by Vinford
1979 F-250 4x4
As original:
The brass block where the two steel lines attach and has the hole for the rear axle vent tube is part of the rear brake flexible hose.
The block was not available by itself, as there is no way to attach the flexible hose to it.
D8TZ2282C .. Rear Brake Hose & Fitting (brass block) / Obsolete
Fits: 1976/79 F100/250 2WD / 1978/79 F150/250 4WD / 1979 F350 4WD.
DON SANDERSON FORD in Glendale AZ has 8 = 623-842-8762
KINSEL L/M in Beaumont TX has 1 = 800-816-2894
GREEN SALES CO. in Cincinnati OH has 9 = 800-543-4959
nonrev321
04-08-2016 09:38 PM
cityjack
13
04-07-2016 08:45 PM
BDawg171
17
04-08-2014 01:09 PM
jrockdiddy
03-09-2014 12:17 PM
fitz1898
1997 - 2003 F150
12-12-2009 08:25 PM
Quick Reply: Rear brake lines
