Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 05-06-2009, 10:45 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
A 351 computer would be optimal, but the 302 computer should get it up and running.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #32 (permalink)
Old 05-07-2009, 07:09 AM
baldboyford baldboyford is offline
baldboyford is starting off with a positive reputation.
My apologies to Conanski, EPNCSU2006, and the rest in this thread, apparently I am still behing in the conversation. ranger6202, you need to read this thread from the beginning and your computer questions should be answered.
__________________
Baldboyford
97 EB Explorer 5.0 AWD
96 F150 XLT Ext Cab 393 4R70W 4X4
  #33 (permalink)
Old 06-21-2009, 10:44 PM
ranger6202 ranger6202 is offline
ranger6202 is starting off with a positive reputation.
I forgot to ask if the clutch is different for a 351w than a 302.
I did find a 351 ecm....but as i was digging around in a few yards i've noticed that some of the 351's have blue ring injectors.....i think those are 24#'s but i'm not sure....should i go with the blue ones or my yellow 19#'ers.
  #34 (permalink)
Old 06-22-2009, 05:43 AM
EPNCSU2006's Avatar
The 351 should have 19 lb/hr injectors from the factory. The 460 is the only engine I know of that used the blue 24 lb/hr injectors in these trucks.
__________________
Eric
  #35 (permalink)
Old 06-22-2009, 07:54 AM
I believe the clutch is the same for the 302 to 351. To eliminate any doubt, just use or buy one for an F150 with a 351 from the factory. If you are going to leave the 351 stock, the 19lb injectors will do fine. Even if you do some mild mods the 19lbers will work properly for you. The wilder you go with the mods, the more need for more fuel, hence the 24lb injectors will come into play.
__________________
Baldboyford
  #36 (permalink)
Old 06-22-2009, 12:24 PM
loudfords's Avatar
loudfords loudfords is offline
loudfords is gaining momentum as a positive member of FTE. loudfords is gaining momentum as a positive member of FTE.
Quote:
Only up to 91 or 92... Later 351W have 11 9/16" clutch while the 302 kept the 11" clutch. Also keep in mind that 302 & 351 flywheels are balanced differently. Do not mix and match!
__________________
Chad - loudfords
1979 F150 351W
2001 Focus
Ford LT75 lawn tractor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
