Circuit Breakers Location?
Does anybody know where the circuit breakers are located on a 2003 F-350. I have been posting a thread asking about a problem I am having with the electrical system, I believe I have it narrowed down to the circuit breaker that controls the power window motors. I can not find this breaker, the Chiltons manual indicates that the fuse banks are located under the instrument panel and in the engine compartment, I have checked the fuse bank under the instrument panel but could not locate the fuse bank in the engine compartment. I am not sure if it could be else where because of the motor (Power Stroke). I do appreciate everyone's feed back and thank you in advance for any advise.
Respectfully, Ryan
Respectfully, Ryan
I did finally find the fuse/relay I was looking for. Apparently Ford decided to place all the relays fuses and circuit breakers in one location. but this must be an anomaly since it took me this long to figure it out. I'm being sarcastic, I will let everyone know once I figure out the problem. Thank you for all the advise and input.
Thanks, Ryan
Thanks, Ryan
