What is everybody gonna be working on? - Ford Truck Enthusiasts Forums
Tennessee Chapter Join Chapter Leader:
Old 01-22-2009, 07:25 PM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
Ok it's finally warming up around here and looks like it will be safe to go back in the garage again so whats everyone working on? I got to see what suspension parts need replacing [got a little shake] so I can put my level kit on and get ready for some new wheels.
Old 01-22-2009, 08:32 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.
Well; I'm slowly (green back limited) working the completion of my 78 model for my daughter, then there's my buddies 77 engine compartment I volunteer too paint, then I got a 64 model to "old school". Oh did I mention I been helping build a Habitat home with my union as well. We hang dry wall tommorrow. Need to just learn to say no!!!!!!!
Did enjoy the sunshine today.
Mitch
Old 01-22-2009, 08:59 PM
KDPate's Avatar
KDPate KDPate is offline
KDPate is starting off with a positive reputation.
Converting the truck over to MAF and adding a roller cam in it. Plus giving it a bath and a wax job.....
Old 01-22-2009, 09:26 PM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.
I'm getting new tires for my F250. I have a 4 channel amp to install also. Its been too cold for me to add it. I also have 6 rolls of Dynomat to put in it. I have a set of MB Quart 3 way component speakers I could add but I'd have to build custom kick panels or buy a set of Qforms for it. I think they would sound better with a set of custom panels. I have a set drawn up so I just need to get busy & build them. It all depends on which job I take. If I get a company truck I'll go all out on the sound system in my F250. I have plenty of equipment to make it a show quality system..
I'll know about the job in a week or so.
Old 01-22-2009, 09:52 PM
LiftTech LiftTech is offline
LiftTech is starting off with a positive reputation.
Finish some work on my shop (replacing a rotten beam, installing some lights), then I need to replace the wood in my flatbed. After that I've got a '48 8N that needs to be split and overhauled, and I'm hoping to paint it when I have it apart.
Old 01-23-2009, 09:18 AM
TN97STROKE's Avatar
TN97STROKE TN97STROKE is offline
TN97STROKE is gaining momentum as a positive member of FTE.
Frame off build of 68 Bronco. Dana 60 front, Dana 70 rear, 4 wheel disk, 203/205 twin stick transfer cases, hummer double bead locks, on board air, on board welder, full custom suspension. and much much more.
Old 01-23-2009, 11:04 PM
lariat97's Avatar
I have my stereo system ready to install. My door speakers are being driven by a 2 channel Kenwood amp now.I will replace it with a Phoenix Gold ZX475 Ti. I can fade the front & rear speakers then. I am also adding my Phoenix gold EQ 215iX to add more control to my system. I will continue to use the JL Audio 500 mono sub amp for the subs. Later I'll build speaker pods for the MB Quart 4 inch & tweeters &mount the 6.5 inch mid bass speakers in the factory speaker mounts. I think it will sound real good. I won several local competitions with these speakers & the one 4 channel amp.I don't plan to enter any contest now. I just want to use the stuff instead of letting it fill a closet in my house. The Dynomat will make my truck real quiet inside. It should stop most of the road noise. I think it will be a great mod for my truck.
Old 01-24-2009, 12:18 PM
torkum's Avatar
Looks like everybody has plenty to do but where's the pics
Old 01-24-2009, 06:19 PM
lariat97's Avatar
I'll post pics once I begin the tear down. I plan to remove the seats to make running the wiring easier.It will also make installing the dynomat behind the rear seats much easier. At least I have a good heat gun this time.I would lay the mat in the sun to get it hot so it would bend easier when I did my old truck With the heat gun & a roller I'll get it done much faster & do a better job.It made my last truck as quiet as a caddy.It also made the stereo sound much louder. It wasn't really louder it just stopped all the rattles & other noises
Old 01-24-2009, 08:01 PM
Customcab's Avatar
Man you guys with the high tech radios' no wonder I get laughs when folks see my 8 tracks.
Man I got to upgrade....
Mitch
Old 01-24-2009, 11:29 PM
KDPate's Avatar
Quote:
Taking the farm truck a step further..... - SVTOA Nashville Forums
The thread to my project.......
Old 01-25-2009, 06:32 PM
Customcab's Avatar
Kevin;
Now that's more challenging to wire up then my 8 tracks for sure. Dealing with the mass air flow & sensor's way beyond my Shade Tree skills.
Mitch
Old 01-26-2009, 09:41 AM
KDPate's Avatar
It's onlu part ofthe project Mitch. I still have to fabricate the air intake and the brackets to hold the MAF in place. Also had to make a tool in order to get to the T-40 bolt that Ford used on the intake....
Old 01-26-2009, 06:42 PM
Customcab's Avatar
Good luck Kevin; your task will help others to do the same..
Mitch
Old 01-27-2009, 09:59 AM
KDPate's Avatar
Quote:
Mitch
Plan on bringing the write up over here when completed....
4 bbl going on! flipklos Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 02-26-2009 02:27 AM
Wrench warning light STX04 2004 - 2008 F150 2 07-28-2008 10:54 AM
Rear ABS and Brake lights came on! buckeyebronco 1978 - 1996 Big Bronco 6 07-07-2008 10:54 AM
help...I have wobble austinpower 1987 - 1996 F150 & Larger F-Series Trucks 3 09-08-2006 08:18 PM
Oh No I Am Hooked odie780 General NON-Automotive Conversation 16 04-28-2002 08:47 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
gold, phoenix, specs, ti, zx475
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
