Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-21-2009, 10:58 PM
Dean88's Avatar
Dean88 Dean88 is offline
Garage is empty, add now
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
Negatives of Algae bio diesel
First off, I'm a supporter of Algae bio diesel and all bio diesel research
Here's my story, I'm a in CX debate and district is in a few weeks and its already matching up that my team is going to be going head up against an old enemy team. Anyhoo after some scouting I've found out that their case is to do some smudging of the DOE budget at allocate 1 billion dollars into bio diesel research. Generally these hard core debates between two good teams end up debating small stupid details and don't involve the actual plan at all. This year I am going to ram their plan head on because I know they don't know anything about bio-diesel.
So, here's my question can ya'll help me out and give me any and all negatives associated with it. Higher gelling temps or anything like that?
__________________
1999 F250 7.3 ZF6 4x4 3.73's 200k miles
1997 F250 7.3 ZF5 2wd 4.10 430K miles
Dr. Ron Paul 2012!!
  #2 (permalink)
Old 01-22-2009, 06:55 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Sorry...........I know of no negatives regarding algae biodiesel..........
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 01-22-2009, 08:04 AM
Dean88's Avatar
Thats what I was afraid of. I'm scouring the net for even the smallest negs, such as higher gell point or such, but am having serious trouble trying to find any.
__________________
Dr. Ron Paul 2012!!
  #4 (permalink)
Old 01-22-2009, 09:27 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Biodiesel in general is a winner.
Algal Biodiesel is a double win because it does not affect food crops, as plant based BD can.
The one negative, and this is BD in general not specific to algal BD, is a slight increase of NOx emissions. NOx is a generic term for a group of nitrogen oxygen compounds that are formed during combustion, it is a pollutant. The EPA has a mandate to reduce NOx emissions and work is proceding on developing a method to do that. One promising technique involves extracting hydrogen from fuel before it is burned then injecting this hydrogen into the exhaust stream under specific conditions the result is Nitrogen and water. Here is a link to a page on the subject
Nox reduction system for diesel engines, using hydrogen selective catalytic reduction invention
You may have to copy and past to get this link to work.
There are other techniques being worked on.
While there an increase in NOx from use of BD virtually all other pollutants are decreased, including CO2 and sulpher compounds.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #5 (permalink)
Old 01-22-2009, 09:32 AM
Dean88's Avatar
Thanks, thats exactly something I am looking for, they won't have a clue about BD decreasing other pollutants or NOX reduction.
__________________
Dr. Ron Paul 2012!!
  #6 (permalink)
Old 01-22-2009, 02:05 PM
Phydeaux88's Avatar
Here is a link on the subject of BD emissions
http://www.biodiesel.org/pdf_files/f.../emissions.PDF
__________________
  #7 (permalink)
Old 01-22-2009, 03:03 PM
1935 Ford pickup
I thought you were just interested in negitives.............
Some good info here: First Algae Biodiesel Plant Goes Online: April 1, 2008 : Gas 2.0
__________________
  #8 (permalink)
Old 01-22-2009, 09:08 PM
1994diesel's Avatar
1994diesel 1994diesel is offline
1994diesel is starting off with a positive reputation.
i have heard that algae biodiesel is less stable than veggie biodiesel.
__________________
Justin
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, IP turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
  #9 (permalink)
Old 01-22-2009, 10:24 PM
Dean88's Avatar
oops fabman, your right, what I meant to say is they won't know about decreasing pollutants and NOX reduction, so I can run that BD causes much higher NOX amounts without fearing they can refute it.
__________________
Dr. Ron Paul 2012!!
  #10 (permalink)
Old 01-25-2009, 09:51 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is online now
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
I have a chemist friend who has been in VO industry for over 25yrs. He is concerned about the potential it may not smell very good. The algae has alot of similarities to fish oil - chemically. The stability of ALL vegetable-based oils is a big issue. The biodiesel industry is struggling to extend the shelf-life of its fuel. Currently, no bio-d at the pump meets the ASTM standards for fuel. This is largely why no OEM recommends more than a B5 blend in their vehicles.
__________________
2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop View Post
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
  #11 (permalink)
Old 01-26-2009, 09:37 AM
Phydeaux88's Avatar
Quote:
A little correction here if B5 is blended with good quality BD, meets ASTM D6751 for blend stock, it will meet the ASTM standard for petro diesel ASTM D975.
As of June last year the ASTM International D02 Main Committee approved a change to ASTM D6751 that provides a standard for B6 thru B20.
You will have to give the EMA (Engine Manufacturers Association) a little time to evaluate it and ensure their engines wont have problems with it.
By the way the OEM is only responding to EMA recommendations with their B5 limits. That limit was there because there was no standard for BD other than that for blending stock.
__________________
  #12 (permalink)
Old 01-26-2009, 05:39 PM
Actually, its a direct response to problems Bosch and other manufacturers have been facing. They have been finding polymerized oil to be the failure mechanism, specifically in IP's w/extended biodiesel use. The problem is directly related to the usable shelf life of biodiesel - polymerization is the natural degradation of VO. The industry is still experimenting with antioxidants and chelating agents capable of extending the life (and ASTM standard compatibility) to more practical times. It is the 'stability' aspect of the fuel that fails to meet the standard by the time it reaches the pump. I can tell you the large american oil supplier I've been working for tries to keep the B99 stock they blend B5 with to a minimum - they've already learned alot the hard way. If you remember even 15-20 yrs ago, gasoline left in your lawnmower or dirtbike over the off-season was enough to cause havoc. They have gotten the stability of gasoline and diesel MUCH better. Its just gonna take'em awhile to get it dailed in for bio-d.
__________________
  #13 (permalink)
Old 01-27-2009, 12:00 PM
Phydeaux88's Avatar
There are several relatively easy techniques to reduce the polymerization of BB.
1 Store it in a tank lined with non metallic material.
2 Store it under a head of nitrogen
3 Do not heat any more than necessary after processing.
4 Eliminate potential bonding sites by hydrogenating or use saturated oils as input.
These steps will not totally eliminate polymerization but will significantly reduce it.
__________________
  #14 (permalink)
Old 01-27-2009, 01:09 PM
I agree. Oxidants, such as copper and carbon steel enhance polymerization. So does exposure to heat, oxygen, UV light and several other factors. What this does not address is biodiesel/VO that finds itself trapped inside IP's and other engine components. This is what reports from Bosch and other manufacturers/vendors that recommend no more than B5 are referring to. It is important to note we are not preventing polymerization w/these efforts - just slowing it down. I have had issues running B100 in my diesel tank while primarily burning SVO from other tanks. The problem I've had is related to the B100 that finds itself cooking in the factory filter bowl while I drive 1000's of miles on road trips while burning VO. The fuel in factory diesel filter just sits there (diesel pump is turned off) while I'm running on VO. My diesel tank became 'contaminated' with this polymerized biodiesel material when I switched back to diesel and the unused fuel in bowl began returning to diesel tank. Until I get an adequate fuel stabilizer for my biodiesel - I will not be using it in my SVO-converted PSD's... My diesel system is 100% stock with the addition of 'real' checkvalves that prevent VO from contaminating diesel system and the ability to turn off the diesel fuel pump.
__________________
  #15 (permalink)
Old 01-27-2009, 04:18 PM
Phydeaux88's Avatar
What you describe sounds like problem that is specific to trucks that burn primarily SVO and switch to BD for startup/shutdown.
If you run BD only you should not experience such difficulty, as proven by the many folks that have been running strictly B100 for years.
The problem of keeping a small amount of BD in a very hot, polymerization inducing environment, for an extended period of time would not exist. The fact that your problem is limited to the BD side of your fuel system supports that conclusion because VO is every bit as likely, possibly even more so, to polymerize as BD.
In you position I think the decision to run straight #2 in the non VO circuit is correct.
__________________
Tags
73, algae, bags, biodiesel, biofuel, desiel, ford, growth, microalgae, negative, negatives, oem, oil, pyrometer, standards
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
