Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 01-21-2009, 07:02 PM
Haveyoudrivn1lately? Haveyoudrivn1lately? is offline
Garage is empty, add now
Haveyoudrivn1lately? is starting off with a positive reputation.
Talking 99 F250 Keyless Remote Entry ?
I recently purchased a 1999 F250 S/D v10 5 speed ext. cab and only received one ignition key (no keyless entry fobs).
The truck does not have a keypad on the doors, but if this truck has the remote keyless entry option, how can I tell?
  #2 (permalink)
Old 01-21-2009, 07:11 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Follow the steps to program in the transmitters. I have posted them below. If the locks don't lock/unlock after turning the ignition on/off 8 times you don't have keyless entry.
To reprogram all transmitters, place the key in the ignition and turn from
OFF to ON eight times in a row (within 10 seconds). After doors
lock/unlock, press any control on all transmitters (up to four). When
completed, turn the ignition to OFF.
All transmitters must be reprogrammed at the same time.
One thing I should mention, Off is not the position where you can take your key out. That is considered Lock. The first click forward is Off, the second click forward (when your radio and climate control turns on) is On, and past the On position is where your truck tries to start. Some people get confused and try to turn back and forth in between On and Lock and that doesn't work.
I'm pretty sure we figured out that the hard wired entry keypad was a seperate option from remote locks up until 2005 when they grouped them together as the Advanced Security Group.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #3 (permalink)
Old 01-21-2009, 07:21 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
If you don't have it, you can get a keyless entry system installed at most alarm shops, or buy the aftermarket set up and do it yourself if you know how to wire things up. You can also buy a stick on key pad from Ford and add that to your truck if you want one.
Welcome to FTE.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 435,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #4 (permalink)
Old 01-21-2009, 07:28 PM
I think the stick on keypad only works if he has the Ford keyless entry system.
If he doesn't then yes there are many aftermarket kits that can be added fairly easily since he already has power locks. He may even want to think about getting and alarm, remote start, or a combo unit with alarm and remote start as many of those can add keyless entry also.
__________________
  #5 (permalink)
Old 01-21-2009, 08:01 PM
F350-6's Avatar
If you can get into the programming mode of the aftermarket set up, you can add the Ford key pad as long as the system doesn't require you to push the lock and unlock buttons at the same time.
__________________
Chris
  #6 (permalink)
Old 01-21-2009, 10:26 PM
ameinig ameinig is offline
ameinig is starting off with a positive reputation.
I have a 1999 also that I bought from the original owner. Mine has Ford Keyless entry, but it is a dealer add. I think all 1999s that had keyless were this way. It still has all of the install/operation manuals in the glovebox. Maybe you can still get the kit from Ford.
  #7 (permalink)
Old 01-22-2009, 06:01 AM
F350-6's Avatar
Quote:
I had a 99 that came with factory keyless entry, so it was available.
__________________
Chris
  #8 (permalink)
Old 01-22-2009, 07:25 AM
DetailerDave's Avatar
DetailerDave DetailerDave is offline
1999 Ford F-250
My Garage
DetailerDave is starting off with a positive reputation.
My 99 also has keyless from factory.
__________________
99 F250 SD SuperCab 4x4 V10
95 Mustang Coupe V6
  #9 (permalink)
Old 01-22-2009, 08:53 AM
juneau76's Avatar
juneau76 juneau76 is offline
2010 Ford F-150
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
I had the same dilemma when I got my truck. I bought an OEM keyless system only to get build sheets that showed keyless was already installed. Yes, I did it a little bassakwards. I still have the OEM keyless kit here if you end up not having it and want it. It would only require a small donation to help offset my own financial crisis.
__________________
Brad
2010 F-150 XLT Supercrew 4x4 5.4L
2013 Explorer Limited (The wife's family truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #10 (permalink)
Old 01-27-2009, 07:10 PM
Thanks for the info - Keyless entry
Thank you to all of you for the info. Sorry I am so late getting back to you. I washed my 6.8 (the engine itself) the other night to get the road salt off and have now learned NOT TO DO THAT. Trying to find the bad coil and/or plug on a v10 is like playing whack-a-mole at Chucky Cheese.
Juneau76 I may take you up on that keyless system once I see what my current damages$$$ are.
  #11 (permalink)
Old 04-12-2009, 08:30 PM
SC_Dave's Avatar
SC_Dave SC_Dave is offline
SC_Dave is starting off with a positive reputation.
Hey guys answer this....
My remote (or the part that hooks onto my key ring) broke so it's loose from the ring and I hate that. Can you one from the parts house or does it have to be OEM.
David
__________________
2002 F-250 Super Duty Lariat 4X4 Crew Cab 7.3 Power Stroke Diesel, 3.73LS, Automatic
ARE Cover, AIS, 4" Turbo Back Exhaust
  #12 (permalink)
Old 04-13-2009, 08:22 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
FWIW my 04' F-250 XLT SC didn't come with keyless entry or the door keypad. You can get a DEI system equal to the factory system for under $150 installed.
David
Keyless Entry Remote Key Fobs, Remotes & Keys for Cars
  #13 (permalink)
Old 04-13-2009, 04:43 PM
SC_Dave's Avatar
I just need the key fob. I have an extra from my wife's 04 Taurus, can I reprogram that one for my truck?
David
__________________
  #14 (permalink)
Old 12-26-2010, 09:47 PM
phillipmccarthey phillipmccarthey is offline
phillipmccarthey is starting off with a positive reputation.
keyless entry
Question:
So, if your truck doesn't have the keyless entry installed from the factory and the method above doesn't work would there be a plug under the dash so a person could add the VSM box ?
2002 F250 Diesel 4X4
  #15 (permalink)
Old 09-10-2011, 06:59 AM
cds's Avatar
cds cds is offline
cds is starting off with a positive reputation.
I have keyless entry with 2 fobs but I would like to add a keypad as I also found the keylock on the drivers side does not work. I may go to the dealer and see about the stick-on keypad option. Any idea how much they cost??? I just thought of something...if the keyfob does not unlock the doors when the truck is running will the keypad?? It does on my wifes car, it is factory and it did on my Expy, also factory. Just wondering??
__________________
1986 F-150,5.0,4X2,AOD,XLT Lariat
1999 F-250 SD,7.3,Auto,4x2,XLT,Supercab
2005 500 SE AWD
2003 Honda Rancher ES 4x4
Tags
1999, 99, dont, entry, f250, ford, fords, keyless, keypad, locks, oem, remote, remotes, truck, work, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
