Transmission check ball locations - Ford Truck Enthusiasts Forums
Old 01-21-2009, 03:29 PM
Roj1234 Roj1234 is offline
Roj1234 is starting off with a positive reputation.
I have a 1992 f350 7.3l, it has a e40d automatic transmission. I am trying to find the location of the check ***** to re-install the valve body.
Old 01-21-2009, 03:30 PM
I forgot to mention i will need a picture of the transmission to help me find it.
Old 01-21-2009, 04:38 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I have one at home that I made on my '93, I bet they are the same. I hope I can remember to post it for you tonite.
Old 01-21-2009, 07:14 PM
I think they are the same too. Please try to remember it would be verry appreciated. Thanks
Old 01-21-2009, 07:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Roj1234,
Welcome to FTE and the IDI diesel forum.
Old 01-21-2009, 09:42 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
I have a scan of the page you need, but I might be breaking forum rules if I post it on the forum.
Dave can I post here, or would it be better to go direct to his Email?
Old 01-21-2009, 10:48 PM
jas88's Avatar
As promised:
There are 9 checkballs, F1 and F2 are filter screens.
Check Ball in thermostat housing question... awhtx Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 08-01-2016 02:42 PM
86 F350 ball joint question Joe the bartender Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 03-11-2015 03:15 PM
Need help finding NOS Gear Shift Lever Knob for 65' redstarr1000 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-27-2014 06:37 PM
Check Your Balls! FORDF250HDXLT Clutch, Transmission, Differential, Axle & Transfer Case 3 04-08-2013 08:11 PM
C4 Direct Clutch Piston shark13 Clutch, Transmission, Differential, Axle & Transfer Case 4 11-28-2010 01:38 AM
Tags
1992, 4r70w, 92, 97, aod, ball, balls, body, check, e4od, f150, ford, location, locations, transmission, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
