Rear End Clutch packs
Old 01-21-2009, 02:16 PM
Mac88's Avatar
Mac88
Mac88 is offline
Can someone suggest what I should do about this. I took it to dealer when it was in warranty and got this fixed and now it's shuddering again. Where is a good type of place to get this fixed? No more warranty. Should I get a different design?
Old 01-21-2009, 02:56 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
i'd vote for a new...non ford limited slip...i really liked the eaton i had in my 95...i'd consider another....
Old 01-21-2009, 03:12 PM
jstnromero's Avatar
jstnromero
jstnromero is offline
x2 on eaton....they make a great product.
Old 01-21-2009, 03:36 PM
HYPO's Avatar
HYPO
HYPO is offline
+3 on the Eaton. I have an Eaton TrueTrac installed in my 2008 Screw and it is great! Silent, smooth, and imperceptible when it locks up. No clutch packs to change, in fact, no maintainance at all. I'm going to install one in the front diff soon.
HYPO
Old 01-21-2009, 07:27 PM
Catmonkey's Avatar
Catmonkey
Catmonkey is offline
The Ford OEM units are not near as stout as the Eaton. I'd replace rather than rebuild, but it will be a more costly alternative.
Old 01-22-2009, 05:58 AM
06supercrew's Avatar
06supercrew
06supercrew is offline
When I started having problems with the clutch pack on my truck it was after they had replaced some bearings in the rear-end (could be coincidence?). I was 600 miles from home when the clutches started to act up.
I took my truck to the local Ford dealer where I was, the mechanic checked it out and told me it was the clutch pack, when he found out I had just had the bearings replaced he suggested adding some additional (I don't remember what he called it) conditioner required for this rear-end. I felt he was looking out for my pocket and I appreciated it.
He said if too little of the conditioner was added it could cause this to happen and he had seen the problem go away when the proper amount was added. When I told him it was still under warranty, he said he would replace the pack.
When I picked up my truck, he told me according to the warranty repair sheet when the bearings were replaced they had not added the proper amount.
If you can, check to see how much of this conditioner was added at the last repair, how much should have been added and if you can add any more. It might work and save you some $$$.
If you allowed the rear-end to be serviced by one of the quick oil change shops, you probably don't have any in it.
Sorry for so long of a post. For what it is worth Graham Ford in Mansfield, Ohio was the dealer and they were great.
Old 01-22-2009, 10:52 AM
jstnromero's Avatar
jstnromero
^^ is the conditioner that you are speaking of...the friction modifier?
Old 01-22-2009, 01:14 PM
06supercrew
Yes, I believe it is.
Old 01-22-2009, 02:01 PM
Silver Streak's Avatar
Silver Streak
Silver Streak is offline
If the rear is an 8.8 you can buy the clutch pack from Summit for about $50 and they take about half an hour to change if the preload spring doesn't screw you to badly. If it's a 9.75, it is worth your money to have someone do it. The Eaton is a great upgrade, but once I put the clutches in mine the right way (Ford does it wierd) it has given me no further trouble.
Old 01-31-2009, 07:26 AM
Djack04F150XL's Avatar
Djack04F150XL
Djack04F150XL is offline
I had my clutch pack, bearings, ring and pinion replaced under warranty at 35K. I now have 74K and the only problem I have is when I let off and give it gas it gives a jolt when they lock up. I have the 9.75. Is there a replacment TrueTrac for this or is it the Eaton limited slip? Also, does Eaton make a ring and pinion set for the 9.75?
Old 01-31-2009, 09:23 AM
Ryan50hrl's Avatar
Ryan50hrl
Both eaton limited slips and truetracs are available for the 9.75.....are you changing gear ratios because you can reuse the ring gear if your staying with the same ratio...
Old 01-31-2009, 09:42 AM
HYPO's Avatar
HYPO
HYPO is offline
Eaton makes both a True Trac and a limited slip for the 9.75. I feel the True Trac, though a bit more expensive, is a much better alternative. There are no clutch packs in the True Trac. It is a gear drive affair which is silent and seamless. I have one in my rear diff and will soon be putting one in the front.
HYPO
azchris
6.7L Power Stroke Diesel
15
08-26-2013 10:43 AM
952X4
83
06-20-2013 01:52 AM
Daveyf15096
1999 to 2016 Super Duty
06-19-2013 04:56 PM
RetroActv
1997-2006 Expedition & Navigator
03-10-2010 06:18 PM
Jackflack
Car/truck Buying Advice
03-28-2004 07:35 PM
Quick Reply: Rear End Clutch packs
