98 4x4 Wheel Interchange? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-20-2009, 04:12 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
What other stock wheels will fit a 1998 Ranger 4x4. There seems to be something unique about the front hubs that limit junkyard wheel choices. Any experts out there?
Jim
Old 01-21-2009, 05:52 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
A jeep has the same bolt pattern, but there's is a difference in front hub size on the 4x4's.
Old 01-21-2009, 10:33 AM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
jeep alloy rims need machining to fit over the ranger front hubs, the steelies however will work. i run '01 wrangler rims for my winter set of tires. click this link for alot of rim information: http://www.therangerstation.com/tech...l_fitment.html [/url] heres my '93 with '01 wrangler rims. i did cut out the plastic cap on them for the lockout hub to pass thru.
Old 01-21-2009, 04:55 PM
5.0B2's Avatar
5.0B2 5.0B2 is offline
5.0B2 is starting off with a positive reputation.
Your 98 has hub centric wheels - only hub centric wheels with the same diameter as your hub will fit properly.
Old 01-21-2009, 06:33 PM
I guess the question really is, what other years and models of Fords have the same hub-centric rim style. He found a pair of 16's that fit the hub, but without a full set he cant use the 4x4 here in the snow for obvious reasons.
Jim
Loose steering wheel jimhay 1987 - 1996 F150 & Larger F-Series Trucks 4 04-05-2008 08:56 PM
Lower Control Arm Bushings - Pressed In? jimkari 1997-2006 Expedition & Navigator 4 03-08-2008 10:02 PM
Factory Wheels for 1986 F 350 4X4 jimpennycuff Brakes, Steering, Suspension, Tires, & Wheels 1 07-19-2006 04:06 PM
What Size Wheels Came With My 2002 F250SDCC4X4 With LT235-85-R16E's? ironmine 1999 to 2016 Super Duty 4 02-23-2006 08:16 PM
Will Explorer wheels fit my Ranger? Big Jim M Brakes, Steering, Suspension, Tires, & Wheels 0 09-23-2005 05:44 PM
Tags
4x4, 98, centric, f150, hub, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
