1976 Ford F250 390 CID - Ford Truck Enthusiasts Forums
Old 01-20-2009, 01:43 PM
rodknockingford rodknockingford is offline
rodknockingford is starting off with a positive reputation.
First off I am new to this web site and I am looking to talk with some folks who enjoy Ford Truck as much as I do. I hope there is some one out there that can keep me from pulling my hair out.
I have a 1976 Ford F25) camper special, with a 390 CID, Holley 4 BB Carb, auto transmission. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have been trying to find the vacuum line routing for smog. I have bought books from Ford and Chilton’s Manuals. None give the diagram. It is not on line either from what I can come up with<o></o>
So here are the questions I hope you can help. My truck has a single port vacuum on the distributor ( I am not sure where this goes) . It has a 3 port vacuum post on top of the water pump goose neck for temperature vacuum. ( I am not sure where these go). On the intake manifold just aft of the distributor there is a 2 port tree ( I am not sure where these go) It has a 4 BBL Holley carburetor. With two ports on the left side of the carburetor. ( I am not sure where these go). Under the carburetor is a plate that attaches to the intake manifold with the EGR valve ( I am not sure where this goes) . On the Aft part right side on the intake manifold is a vacuum tree with 4 ports on it, one goes over to the brake boost pump but I ( I am not sure where the rest goes) and in the very back of the motor is a box with 4 vacuum lines coming out and I believe two going in ( I am not sure where these go). And of course the tin cup charcoal canister beside the battery with 3 ports on it. ( I am not sure where these go). All the hard lines I have figured out. <o></o>
Can you please give me some or allot of insight on the routing. thank you for your time
Old 01-20-2009, 02:03 PM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is gaining momentum as a positive member of FTE.
You are in the wrong spot
Check out some of the other forums on here there is a section dedicated to just your era of truck. Those guys will be quite helpfull.
Welcome to Ford Truck Enthusist FTE for short
Old 01-20-2009, 07:18 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
Quote:
what are you talking about? he has a dentside, and he's in the dentside forum.
1966 f100 door tag decode request plum bob 1961 - 1966 F-100 & Larger F-Series Trucks 1 02-10-2015 08:17 PM
'04 expedition cooling gogreenwave Expedition & Navigator 0 02-20-2014 10:46 AM
1976 Emission Controls VACUUM rodknockingford 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-20-2009 07:39 PM
1976 Ford F250 390 CID rodknockingford 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-20-2009 07:28 PM
Riser under carburetor jd_sylvia FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 0 01-18-2005 01:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
