Clicking noise when turning sharp - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-19-2009, 02:42 PM
fawey1 fawey1 is offline
fawey1 is starting off with a positive reputation.
Unhappy Clicking noise when turning sharp
Hello Again, First I have to say that this group has really helped me over the years.
About two months ago I replaced both front wheel barings and also the calipers.
Recently I am getting a clicking sound, which is intermittant, coming from the drivers side wheel when I make sharp turns. It has to be a sharp turn to hear it.
Vehicle is a 1997 ford ranger, 4 cyl, automatic. Miles: 60000. I plan on keeping this truck forever so what ever needs fixed, I fix it or get it fixed.
Any advice on this noise is appreciated. You have not "steared" me wrong yet. No pun intended
Old 01-19-2009, 04:34 PM
I failed to mention this is a 2wd vehicle, thanks again,
Ken
Old 01-19-2009, 06:00 PM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
Sounds like a CV joint going bad.
Old 01-19-2009, 06:11 PM
Does the rear wheel drive 2wd vehicle have cv joints? I know it may sound strange, but I know nothing about vehicles. Thanks
Old 01-19-2009, 07:04 PM
pc09123's Avatar
pc09123 pc09123 is offline
pc09123 is starting off with a positive reputation.
I wouldn't think your rear wheels would have CV joints unless you might have independent suspension and four-wheel steering on the rear end. Usually you can recognize the CV joint by looking for a black rubber boot just behind the wheel hub, and the boot will appear to have ridges on it. Your CV joint is housed inside the boot which allows you to steer the vehicle while in motion. They are fairly painless to replace with a little instruction.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 01-19-2009, 08:19 PM
drb1956 drb1956 is offline
drb1956 is starting off with a positive reputation.
This is a 2 wheel drive Ranger, not front wheel drive!!! Lets try something real simple-look at your tire first, and see if there is a stone or a nail/bolt stuck in it on the outer edge of the tire..if not, jack up the left front (driver side), and grab hold of the wheel and try to wiggle it in and out, or side to side, to see how much play there is in your wheel bearing for one, and if your ball joints are going bad..if you suspect its the wheel bearing, and you can take off the center cap on the rotor, when you wiggle the wheel, you should see it move on the spindle..If thats ok, while your wiggling the wheel, see if the ball joints are loose-also look at your tie rod ends, as these will make noise when going bad..If none of the above is you culprit, pull off the tire, and look at your brakes-is the caliper on solid, or is it loose?? Look at your pads and rotor also-as you can get a pretty good rust bead on the edge of the rotor, and as you turn sharp, the rotor "flexes" slightly, and could explain the intermitent noise.. Make sure there isn't a brake hose hanging off its mounting clip and hitting the tire or rim.. Doesn't hurt to check all of the above just for the peace of mind...Also-"steered" I think is the correct spelling, but I've been known to be wrong!! Good luck!!!
Old 01-20-2009, 04:42 PM
Taumac Taumac is offline
Taumac is starting off with a positive reputation.
Try checking the dust plate behind the rotor could be bent or loose... or could be inner fender well rub
Old 01-21-2009, 07:25 AM
Question Clicking????
[quote=fawey1;7029469]Hello Again, First I have to say that this group has really helped me over the years.
When you replaced the wheel bearings, did you pack them real good with a quality grease, and also the caliper bolts, did you put some hi-temp grease on them too?? How did you tighten up the wheel bearing?? You put in "new" wheel bearings into an old rotor, did you replace the race for the bearing?? Sometimes an old bearing race gets "worn" in a certain way to the old bearing, especially if the bearings were subject to water and mud or dust a lot, and when you replace just the bearing, it can give you problems(had this happen)..Did the cailper bolts show abnormal wear, as the caliper can have excess play.. Check that dust plate behind the rotor as the other poster said-could be loose and flexing into the rotor when turning sharply..Also check the plastic shield in the fenderwell hasn't come loose, the one piece thats over the top of the upper ball joint thats has those plastic "screws" to hold it in place, so it hits the wheel when you turn sharply..just food for thought!!! Good Luck!!
Clicks when turn sharp. CV joint? accent2010 Escape & Escape Hybrid 3 03-10-2017 03:22 PM
1990 f-250 clicking sound. kilo82 1987 - 1996 F150 & Larger F-Series Trucks 2 07-09-2013 08:35 PM
08 F250 4X4 Front axle clicking when making sharp low speed turns MRTQV10 Modular V10 (6.8l) 5 04-03-2013 11:07 PM
Tires lock up and trans jerk/shift hard when making sharp turns dav3455 1997-2006 Expedition & Navigator 4 06-03-2011 09:48 AM
thumping noise when turning. kystangbanger 6.0L Power Stroke Diesel 11 04-07-2009 08:47 AM
Tags
bead, car, clicking, ford, lube, makes, noise, ranger, rwd, sharply, sound, tarus, truck, turning, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
