4.6 DOHC into an 1998 F-150 or Expedition? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-18-2009, 11:05 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
I'm about to make the swap of a '93 Mark VIII engine into my '98 Expedition 4X4. The research I've done makes me believe it should not be too much of a problem. The major concerns are the ECM and the exhaust, especially the driver side exhaust, the Mark VIII has the Cat. welded directly to the manifold and there may be some interference with other chassis or drivetrain components. If there is I hope to get around this problem by using the left side exhaust manifold from a Mustang Mach 1 that is the same as a Cobra.
The ECM is a guessing game but I believe the Expedition unit will work properly as the same swap has been done in many V8 Mustangs and T-Birds. The pin count and arrangement of the Expedition are the same as the '96 Mark VIII. The only problem I can see so far is that several of the sensors may have the connecting wires cut and spliced as well as using the basic engine wire harness from a '96 Mark VIII as the connector pins changed from a large diameter on the OBD I system to a much smaller diameter in the OBD II system. I also intend to use an electric fan for the cooling system instead of that big clunky OEM fan and that way there may be enough room for a turbocharger.
After the bolt in procedure the Expedition will go to the muffler shop for pipe fabrication.
Another feature of the '96 Mark VIII engine is that it uses the same coil packs as that used on my Expedition
I will post the results with pics when the truck is driveable
Any info would be greatly appreciated.
Old 07-20-2014, 11:09 AM
yark2moung yark2moung is offline
yark2moung is starting off with a positive reputation.
How did the conversion go im about to attempt a 93 mark viii into a 98 expo do you have any advice or tips to make this process a little smoother?
F100 with 4.6 DOHC MARK VIII fuel pump question. bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 10-06-2015 07:42 AM
130Amp 3G alternator w/ wires and Mark VIII electric fan connectors w/ wires ManfredVonRichtofen WTB - Parts & other 2 06-06-2013 07:36 PM
Mark VIII fan JB78f150 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-19-2012 07:42 PM
Mark VIII vs. CV Osiyo59 1961 - 1966 F-100 & Larger F-Series Trucks 8 08-27-2011 10:43 PM
Mark VIII / Taurus Electric Fan Swap mudder1_2000 1997-2006 Expedition & Navigator 17 02-14-2010 09:49 AM
Tags
150, 1998, 46, 98, dohc, engine, expedition, expediton, expidetion, f150, ford, mark, navigator, swap, viii
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
