is it possible to open/close vgt vanes with tuner?
hey guys, as you probably well know took my truck to the dealer the 3x time in 4yrs o ownership for stick turbo issues, is it possible to open and close the variable vanes on the turbo with a tuner? my friends 08 when it starts it opens and closes the vanes on the big turbo to keep them from sticking. i believe it does this on shut down also to prevent the infamous sticking issues with our turbos. can a tuner be programmed to do this on start-up and or shut-down to prevent sticking issues and why has ford not thought of this from the get go. in my opinion it would go a long way to prevent turbo cleaning issues for a majority of customers who have repeated high/low boost and cyl head gasket issues, am i wrong? can this be done or is it a pipe dream?
i also wanted to be able to do this though, so i could get the sound of the rumble when the truck is idling, instead of the turbo when i had a straight pipe, here is a gm that has it done
YouTube - LLY Duramax idle
i had the flash for the egr shut off after 4-5min idling and the turbo vane cycling during idling periods but i unplugged the egr and dummy valved it, but this did not work correctly and the turbo is sticking again, too bad somebody could make a dial you could install with a sct tuner and custom tunes that would allow you full control over the vgt part of the turbo actuator to turn it from 5%-90% duty cycle this would shourly help with acceleration and hill climbing for shure.
CHECK THIS LINK OUT:
PPE Boost Controller for the Duramax
this is what i thought we could do the the 6.0L
dial the boost from 0-25psi to prevent turbo sticking.
is the turbo for the dmax similar to the 6.0? is it
electronically controlled and hydraulically actuated like the 6.0L?
or is it just electronically controlled like the 6.4L turbos are?
This is my first post here , found you guys on Diesel stop, any way sticking turbo could you explaine Mine ( 04 -6.0 cc 350- 4x4 ) has got something going on that feels like a sticking turbo but only 1000 miles on new turbo and egr valve , still acts like no turbo ,really bad when cold -15 below still but not as bad at 0 and above , any help would be awesome , Thanks Larry
Simps
03-17-2017 08:37 PM
Lead Head
09-14-2016 03:14 PM
