2 post lift/shop pix added to gallery
Bob, I never get the opportunity to paste no matter what I seem to do. I have come at about every way that I can think of. The key is that I can never get the url pasted into the screen the pops up in my upper left when I right click on on the picture in my gallery. I can't grab it, drag it or kidnap it. I even tried typing in the url directly-no luck. I must be even more computer challenged than I originally thought!
I never get anything that says "cut" either.
Thanks for your help. I must be a hopeless case.
Now it is on to the real work.
Bill,
I'm not a computer guru by any means, I just fumble around until I find what works. I have two computers, one at home and one at my shop. I bought both of them from the same place, less than six month apart, set up the same way and they both have different quirks. It seems that I have to do some things differently on each of them so I'm guessing your computer might not work in the same manner as mine. I am running a PC with XP and Internet Explorer, your system most likely has different components and different versions of software than mine so it might operate differently than mine. There are just too many variables to know exactly what has to be done. I suggest that you just keep playing around until you stumble on to the right procedure.
Great to see some photos of your garage Bill love the lift.
I was offered a 4 poster lift a few year back £150/$225 was a big strong set up took my F100 no trouble. But I had to say no as I didnt fancy raising the roof in my garage and also would of filled it width wise.
Great when you can do all the work yourself you can have some cool kit, Nice one!
What do you say Dave?
Bill you did a fantastic job raising the ceiling and the lift looks great. I have considered getting one. How about a little more about the lift... make, model, how much weight it holds, how high it lifts, how thick does the concrete need to be, did you install and how (what steps). Did you consider a four post and why did you decide on the two post? Frank
#29
I went through the 2 post or 4 post decision process and talked to others both hobbiest and shop owners that I know. In the end to me it boiled down to get a 4 post lift if you really want to use it for additional storage (one under and one on the lift). If storage is not the reason and you really want it to work on your vehicles then go with a 2 post. That said there are a lot of guys that are happy working on their vehicles with the 4 post.
the 4 post is easier to install, can be mounted on questionable floors and can be easily moved within the shop. Most guys do not bolt them to the floor.
The lift manufacturers vary a little in their floor requirements for a
2 post installation. I had poured my shop floor 15 years ago. It is a 6 inch floor with rebar on 12" centers with chopped fiberglass in the mix. In retrospect, I wished that I had gotten a 4000# rather than 3000# concrete. I would not want less than 5 " of 3000# concrete.
If I remember correctly I have nine 3/4" Redhead concrete anchor bolts in each of the 2 columns. I rented a commerical drill with a 3/4 bit to drill the holes. Drilling time about 45 minutes-cost about $20 for rental-4 hour minimum. You drill all the way thru the floor. That does 2 things, it verifies concrete depth and if you ever want to move the lift you just drive the anchors down into the gravel under the floor and make them flush or below.
Lift specs will tell you lift height. I can just walk under the arms on mine without ducking at all. I am 5' 10". The vehicle will be higher than the arms.
You did not ask specifically about raising the ceiling. That was over 95% of the whole job. I could have installed the lift alone but had a friends help to position the posts. I rigged and moved them with my engine hoist. The friend just stabilized the columns from swinging while moving and then helped me set the top structure (upside down U) on the columns.
The above may be more than you wanted.
It is a great tool!
#30
Bill thanks for the information. I built my shop with the idea that I would put a lift in sometime in the future. Poured the floor at 6 inches fiber concrete with rebar as you described. But haven't decided if 2 or 4 post is the solution. Its great that you got to see the lift work before you bought it and that you got the tech to help. That is very reassuring. There have been several used lifts listed here on craiglist but they have been disassembled and I am not comfortable with not know they work. 8000 # will allow you to lift some pretty large vehicles. How about some pics with your truck in the air?
