Small problem?
Small problem?
So I lost reverse the other day.
Put her up in the air.
And found this...
Turns out the caliper pins had dried up. Other pad was barely used. Didn't hear/feal a thing. The only downside of having a 4" turbo back on an 03
So I went ahead and did this. Replaced all 4 rotors due to the fronts being somewhat warped. Then put some Billstein 5100's on
All better
Also some pictures of my new headunit
And found this...
All better
On the drivers side over the rear wheel there's a pin that you pull and twist. If you've never had it out before yours going to have to take a torch to it They get stuck pretty easily. You can also try releasing the pin then jacking up the trailer with it still attached. That works sometimes.
4tl8ford
1638
04-10-2024 08:27 PM
93f1505.0L
12-31-2008 06:55 AM
