2005 F350 Axle Shaft Clip
Old 01-17-2009, 05:09 PM
Mark5990's Avatar
Mark5990
Mark5990 is offline
I read all the various threads regarding hub, rotor and axle removal on here, but am struggling to remove the front axle shaft clips from my 2005 F350 King Ranch with auto hubs. Everything came apart fine to this point, but after removing the auto hub I can see that the snap ring assembly is somewhat different than on the pictures here or in the Chiltons manual. The difference is that it appears to be behind a shoulder on the spindle. I tried the snap ring pliers I have, I purchased an $80 pair from NAPA and a cheaper pair from Car Quest, but none will do the trick. Its such a deep reach in and the ring would have to expand so far to clear the shoulder the pliers bind. Is there a special set of pliers for this or am I missing something? Any help would be greatly appreciated.
Old 01-18-2009, 07:25 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Your truck is too new for me to be any use but you might try going to motorcraftservice.com (originally posted by rbaker6336) for instructions. Hope this helps.
Old 01-18-2009, 05:43 PM
Mark5990's Avatar
Mark5990
Mark5990 is offline
I ended up pulling the hub and axle shaft out together to get at the ujoint but still can't get the snap ring off. I'm baffled. Didn't find anything in a quick look at motorcraftservice but thanks for trying.
Old 03-25-2011, 12:55 PM
fyrsail's Avatar
fyrsail
fyrsail is offline
pliers for snap ring removal
the pliers you need are currntly produce by snap on and are part # SRPc9000A witout buying these good luck and have a great day of fun, with these 5 minutes and its off. BTW 30 dollars is what they cost.
VORTMAX_99
1999 to 2016 Super Duty
30
11-26-2016 12:16 PM
hewlettjohn
10-17-2016 07:36 PM
donp68
11-26-2015 11:17 AM
wy4525
06-11-2015 02:35 PM
kelsey344
06-24-2012 08:00 PM
Quick Reply: 2005 F350 Axle Shaft Clip
