Water Pump Removal?
YouTube - 7.3 WATER PUMP INSTALL 1 OF 8 FORD POWERSTROKE DIESEL
This is video 1 of 8 on water pump replacement on a 7.3, I havent watched them, but it may be usefull to you. Good luck.
First thing,to get the Fan clutch off. It was a pain for me,the threads are backwards. After you get the fan clutch off,its kinda simple. I think there are like 6 or 8 8mm bolts that hold it on,before you take the bolts loose,take your belt off. There is a place to put a 1/2 breaker bar/or ratchet to release the tension on the belt. After this, take your hoses off,then the bolts. I got mine at Oreilys $99.99 plus the core. And its lifetime replacement. I may have done mine the hard way,but I took my radiator off plus the fan shroud ,that way it gives you more room to get in there. You will have top,bottom and 1 heater hose to take off.....I also let the air out of my front tires,alot easier to get to everything,instead of laying on the radiator support.....
See post #11:
https://www.ford-trucks.com/forums/7...ater-pump.html
And here:
Diesel-Central.com the technical source for Diesel Truck information, Truck Pulling, and Drag Racing
I just watched all the videos linked above, very nice!
They splain it all.
And here:
They splain it all.
There's a LOT of mis-information out there about reverse threads on the fan clutch, even my "diesel mechanic" told me they were reverse. My Haynes manual say's they are normal threads, and I can assure you they are (after I replaced mine a few months ago). Turn the nut counter clockwise to get it loose. (Scott, not sure why your's was reverse, that's very strange) I used a big wrench on the nut and left the belt on (I was changing it anyway). Give the wrench a few whacks and you'll get it loose. You should be able to spin it off by hand once it's loose. Be careful not to damage your radiator when it comes off, it's a little heavy and a tight space.
The rest is pretty straight forward, just take the hoses off and remove all of the bolts. Pay attention to where they came from, they are different lengths. When you put your new pump in, torque all of the bolts evenly. There is some bad info on a pump replacement web site out there too, it stated something like 40 ft-lbs of torque on the bolts, this is VERY wrong. I believe the correct torque is 18 ft-lbs. I'll have to re-check my manual for this.
Lastly - it's your call, but I'd at least replace the lower hose while I was at it. If you have to replace it later, it'll be after you lost all of your expensive coolant. :-)
I'm not sure what's in your Haynes manual, but here's the front cover and page 3-5 covering fan clutch removal from mine. Since 2001 is in the middle of the range from 1999-2003 I would find it odd that Ford made a few with reverse threads (not impossible, just odd). If that's the case you're going to have a hard time when you go to the auto parts store for a new pump.
